ICE with pointers and ASSOCIATED
OP1
New Contributor III
The following code ICEs with both ifort 2021.13.0 and ifx 2024.2.0:
MODULE M
IMPLICIT NONE (TYPE, EXTERNAL)
TYPE :: T
    CLASS(T), POINTER :: PTR
    CONTAINS
        PROCEDURE :: GET_PTR
END TYPE T
CONTAINS
    FUNCTION GET_PTR(SELF)
    CLASS(T), INTENT(INOUT) :: SELF
    CLASS(T), POINTER       :: GET_PTR
    GET_PTR => SELF%PTR
    END FUNCTION GET_PTR
END MODULE M
PROGRAM P
USE :: M
TYPE (T), TARGET :: X1
TYPE (T)         :: X2
X2%PTR => X1
WRITE(*, *) ASSOCIATED(X2%GET_PTR(), X1)
END PROGRAM P
TobiasK
@OP1
thanks for reporting this. I escalated it to our developers. CMPLRLLVM-60612
In the meantime, a workaround is to use a temporary variable to hold the function result and passing that to ASSOCIATED
TobiasK
@OP1
we implemented a fix which will be included in the next release, 2025.1.
