This is a greatly simplified version of a program that was causing an internal compiler error in IFX 2024.2.0. This issue is also reproducible in IFORT 2021.13.0 Build 20240602.
Command: "ifx ice003.F90 -o ice003.out"
Version: 2024.2.0 Build 20240602
Error: "error #5633: **Internal compiler error: segmentation violation signal raised**"
See line 66 in the program below. The use of the array constructor to concatenate an array and an object that contains a pointer and a type that contains an allocatable seems to generate the error.
ice003.F90
PROGRAM ice003
IMPLICIT none
TYPE :: C
INTEGER, ALLOCATABLE :: Y
END TYPE C
TYPE :: B
INTEGER :: X
END TYPE B
TYPE :: A
CLASS (B), POINTER :: B_Pointer
TYPE (C) :: C_Comp
END TYPE A
TYPE :: D
TYPE (A), DIMENSION(:), ALLOCATABLE :: A_Array
END TYPE D
! Main Program Start
TYPE (D) :: My_D
TYPE (A) :: My_A
TYPE (B), TARGET :: My_B
My_B%X = 4
My_A%B_Pointer => My_B
My_A%C_Comp%Y = 6
ALLOCATE(My_D%A_Array(2))
CALL Add(My_D, My_A)
WRITE (*,*) "X: ", My_D%A_Array(3)%B_Pointer%X
WRITE (*,*) "Y: ", My_D%A_Array(3)%C_Comp%Y
! Main Program End
CONTAINS
SUBROUTINE Add(D_Arg, A_Arg)
CLASS (D), INTENT (InOut) :: D_Arg
TYPE (A), INTENT (In) :: A_Arg
INTEGER (KIND = 4) :: Current_Size, New_Size
TYPE (A), DIMENSION(:), ALLOCATABLE :: Temp_A_Array
IF (ALLOCATED(D_Arg%A_Array)) THEN
Current_Size = SIZE(D_Arg%A_Array, 1)
New_Size = Current_Size + 1
ALLOCATE(Temp_A_Array(Current_Size))
Temp_A_Array = D_Arg%A_Array
DEALLOCATE(D_Arg%A_Array)
ALLOCATE(D_Arg%A_Array(New_Size))
D_Arg%A_Array = (/ Temp_A_Array, A_Arg /)
DEALLOCATE(Temp_A_Array)
END IF
END SUBROUTINE Add
END PROGRAM ice003
Any update on this issue?
sorry forgot to mention that I have escalated this last week to the developers. However, no updates yet.
