I apologize if this has already been asked. I did a search, but did not find it.
I am trying to install v8.0.044 because of a linking problem found in v8.0.47 that has been reported. When installing v8.0.044, I made sure that integration for VS .NET 2003 is selected. After installation, I run VS .NET 2003 and Intel Fortran is not listed on the splash screen on startup. Also the option to create a new fortran project does not exist. Finally, when I open a solution with a Fortran project, it says the application for that project does not exist. I have tried rebooting and uninstalling/installing many times. Is this a bug with the installation of v8.0.044? How are others using this build?
Steve
It's a bug in the installer for versions less than 8.0.045 which occurs when VS.NET is installed on a partition other than the Windows boot partition.
Is there a work around or a way to get it to register? Currently .Net is installed on a different drive than Windows.
See attached file.
