29607 Discussions
Program works compiled with -g but not when optimized.
rajesh_dorai
Greetings!
I have a Fortran program which works well when compiled on Windows (using Compaq Visual Fortran compiler) and UNIX (f77 compiler). It works fine when I compile with ifort using the debug option. When I use the default compile (using -c to create .o and then link) or use optimization flags (-On, n=1,2,3), the code crashes with the following output:
forrtl: severe (64): input conversion error, unit 70, file /icp.pdt
Image PC Routine Line Source
hpemifort.exe 081B5519 Unknown Unknown Unknown
Stack trace terminated abnormally.
The file is UNFORMATTED. On doing a web search, I find that this could be a problem with the code writing to and reading from UNFORMATTED files. However, I am not sure why it works fine with the debug option and not when optimized.
Any help would be greatly appreciated.
Rajesh.
The error message relates to a formatted (or list-directed) input error, not unformatted. This is the sort of problem that is nearly impossible to diagnose from a description. One would have to analyze the program to see what is going wrong.
Please make sure you are using the latest ifort. If the problem persists, submit a reproducible and buildableexample to Intel support.
rajesh_dorai
On doing further experiments with the compiler options, I found out that this is a problem with floating point operations. When I compile with "-c -mp", the program runs fine.
I am also able to run with higher optimizations (O3). I was however surprised when the code took a significatly longer time to run when compiled with "-c -mp1" (about an order of magnitude longer time).
I also did another experiment by compiling the code in Windows using Compaq Visual Fortran. This time I set the flag "Floating Point Underflow" to ON. Sure enough, there was a run time error.
On the whole, the problem was with floating point operations and was got around by using the -mp option.
