IFORT_COMPILER16 not created
Young__Caroline
初学者
1,458 次查看
I am using Visual Studio Professional 2015 Version 14.0.25431.01 Update 3 with Intel Parallel Studio XE 2016 Composer Edition for C++ WIndows and Intel Parallel Studio XE Update 1 Composer Edition for Fortran Windows.  Compiling pure C++ project works fine or FORTRAN projects that call C++ is fine but C++ calling FORTRAN fails to find ifconsol.lib.   When I look at the VCC++ directories / Library Directories the $(IFORT_COMPILER16) macro is used but it is not defined if I select the macros button.  There is no IFORT_COMPILER macro defined.  What do I do to tell Visual Studio the value of IFORT_COMPILER16 should be?
Thank you
Caroline
0 项奖励
9 回复数
mecej4
名誉分销商 III
1,458 次查看
Which version of Intel Fortran do you have installed? Depending on that, you should have either IFORT_COMPILER16 or IFORT_COMPILER17 defined among your environment variables.
You reported that you have "Intel Parallel Studio XE Update 1 Composer Edition for Fortran Windows". That is ambiguous, since that can apply to Parallel Studio 2014, 2015, 2016 and 2017.
0 项奖励
Kevin_D_Intel
员工
1,458 次查看
IFORT_COMPILER16 is a system-wide environment variable setting established during the PSXE installation.
There's different ways to check its setting. Via a command-prompt window, enter: echo %IFORT_COMPILER16%
Via the Control Panel, under System > Advanced system settings, under the Advanced tab,  click Environment Variables, then look under System variables
For the C++ link to resolve the Fortran RTLs, refer to Configuring Visual Studio for Mixed-Language Applications for the one-time VS configuration setup.
0 项奖励
Young__Caroline
初学者
1,458 次查看
I am using 2016.1.146.   So for the Macro to appear in Visual Studio I simply need to define the environment variable as usual.  That was very straight forward;
  I had just not understood the connection between macros in Visual Studio and environment variables .  Thank You
0 项奖励
Kevin_D_Intel
员工
1,458 次查看
I think it probably was clear, but to be certain, you *do not* have to define the environment variable yourself. It is defined by our product during the installation.
0 项奖励
Young__Caroline
初学者
1,458 次查看
Thank you both for your help.  The issue I had was that the environment variable had not been created when I installed Parallel Studio for some reason.  Once I had defined it C++ calling FORTRAN builds without a problem.  If  IFORT_COMPILER16 was not created are there any other environment variables that should exist that are going to catch me out?
0 项奖励
mecej4
名誉分销商 III
1,458 次查看
For the typical user who uses only one (often the latest) version of the Intel compiler, the installer takes care of setting up the global environment. If you want more than one version of the compiler to be available on your system, to be chosen at will, or you wish to use other vendor's compiler packages, you would not want the installer to mess up the global environment. In these situations, the compiler's startup batch files "compilervars.bat", etc., will set up the environment variables for the command window session that the batch file opens.
Typically, compiler packages customize %INCLUDE%, %LIB% and %PATH%. IDE-s such as Visual Studio may also modify file-associations when they are installed or updated.
0 项奖励
Kevin_D_Intel
员工
1,458 次查看
Only a few are created at install time (e.g. INTEL_LICENSE_FILE, INTEL_DEV_REDIST, IFORT_COMPILER16). Some are not unique to Fortran the your C++ installation could also have defined those.
I *think* you are ok but we’d like to inspect your install log files to see whether those contain clues why this happened. If you could please zip up: %TEMP%\pset_tmp_PSXE2016_*\*.* and attach that to a private reply to me then we will inspect those.
A quick way to open the folder associated with %TEMP% is to open a File Explorer window and in the address bar type %TEMP%, and then in the search box filter enter: pset_tmp_PSXE2016_*.*
0 项奖励
Young__Caroline
初学者
1,458 次查看
I am afraid the pset_tmp_PSXE2016_*.* file does not exist in %TEMP% or anywhere else on my PC.
0 项奖励
Kevin_D_Intel
员工
1,458 次查看
Ok. It is actually a folder not a single file. %TEMP% is unique to one’s user login account so perhaps someone else installed the compiler or if not then perhaps they've already been cleaned off.
Our installer developer believes you are ok having defined the variable so no need to dig deeper. Let us know if you see other oddities.
0 项奖励
回复
