Here is a program demonstrating the run-time error mentioned in the title. I believe this is a bug in IFORT 16.0.0
Program test
Implicit None
Type string(slen)
Integer, Len :: slen
Character :: its_value(slen)
End Type string
Type(string(5)), Dimension(:), Allocatable :: my_string1
Type(string(5)), Dimension(:), Allocatable :: my_string2
Integer :: stat
Call allocate_string(my_string1)
If(Allocated(my_string1)) Then
Print '(a, 1i1)', "my_string1 was allocated with len = ", my_string1%slen
Deallocate(my_string1, Stat = stat)
End If
Print *
If(stat /= 0) Then
Print '(a)', "Something is wrong, because"
Print '(a, i3)', "deallocation of my_string1 failed with status ", stat
End If
Print *
!The problem appears to be the value of the assumed length parameter slen inside the
!Allocate statement of the subroutine allocate_string. If we do the allocation outside,
!then the interface of allocate_string seems to properly transfer the value
!of the assumed length parameter slen in and out the body of the subroutine
Allocate(string(5) :: my_string2(3))
Call allocate_string(my_string2)
Contains
Subroutine allocate_string(my_string)
Type(string(*)), Dimension(:), Allocatable, Intent(InOut) :: my_string
! If needed, perform typed allocation with the string len parameter being assumed
If(.Not.Allocated(my_string)) Allocate(string(*) :: my_string(3))
Print '(a )', "I am supposed to print 5"
Print '(a, 1i1)', "I am printing ", my_string%slen
End Subroutine allocate_string
End Program test
Thanks, we'll take a look.
Escalated as issue DPD200380620 - thanks for the nice test case.
