29246 Discussions
IFX 2024.2.1 segfault depending on linked list length
V-T
Consider the following minimal example:
module m
   type node_t
      type(node_t),pointer::next=>NULL()
   end type
   type list_t
      integer::n
      type(node_t)::zeroth
      type(node_t),pointer::last=>NULL()
   contains
      procedure::f
   end type
   type obj_t
      type(list_t)::list
   contains
      procedure::a
      procedure::g
   end type
   interface obj_t
      procedure::new_obj
   end interface
contains
   subroutine f(this,a)
      class(list_t)::this
      real::a(this%n)
      call RANDOM_NUMBER(a)
   end
   function new_obj()result(this)
      type(obj_t),target::this
      this%list%n=0
      this%list%last=>this%list%zeroth
   end
   subroutine a(this)
      class(obj_t),target::this
      this%list%n=this%list%n+1
      allocate(this%list%last%next)
      this%list%last=>this%list%last%next
   end
   subroutine g(this)
      class(obj_t)::this
      real::a(this%list%n)
      call this%list%f(a)  ! segfault occurs due to this call
   end
end
program p
   use m
   type(obj_t)::obj
   obj=obj_t()
   do i=1,3000000  ! this integer must be large to cause the segfault
      call obj%a()
   enddo
   call obj%g()
end
Running the executable compiled from this code using ifx 2024.2.1 with debug flags (`-g -traceback`) ends with a segmentation fault. The problem is caused by the call to subroutine `f` inside of subroutine `g`. Strangely, this problem can be fixed if the integer in the loop is smaller (e.g. 2000000 instead of 3000000). Therefore, I suppose, that ifx generates wrong code.
The debug flags are necessary because otherwise optimization removes the lines causing the problem. (I also have a larger working example that causes segfault even without the debug flags.)
Interestingly, gfortran 13.2.0 also fails to produce working code. However, the NAG compiler (nagfor 7.1) has no problems with this example.
Labels (2)
jimdempseyatthecove
The statement in g and/or f:
with n=3000000
is causing a stack overflow.
To correct this, enable heap arrays, .or., make a allocatable and allocate.
Note, increasing stack size may also work, but this may cause other errors in your program.
Jim Dempsey
jimdempseyatthecove
with n=3000000
Jim Dempsey
V-T
You are right! Thank you for this solution.
I'd rather avoid adding any additional compiler flags in my program, that's why I'll use the solution with `allocate`. So is it better to allocate arrays explicitly inside of procedures than to use automatic arrays? The explicit allocation avoids stack overflow, but are there some performance differences between two approaches?
jimdempseyatthecove
This depends on the size of the arrays. Use automatic for small arrays, allocatable for large arrays.
With an array size of 3000000, the amount of processing time to use that array will (should) greatly outweigh the additional overhead.
Note, if your code is .NOT. parallel, then consider making the array ALLOCATABLE, SAVE .or. ALLOCATABLE and in a module THEN in your procedure test for allocated, if not, allocate. IOW incur the allocation overhead only once.
Or, if the procedure is entered in a parallel region, consider placing the array in a module and declaring it THREADPRIVATE.
Jim Dempsey
V-T
