29422 Discussions
IMSL, Fortran - Rank of matrix function, rank(A), gives wrong results when used in Genetic Algorithm
Xuan-Hoang_N_
Dear friends,
I have got the problem with function of 'rank' when using it as a function calculating rank of a matrix in subroutine which has been called by Genetic Algorithm (GA) in Fortran code.
I have run two separate projects which used rank(A) as a function to calculate rank of matrix A which is built after a long procedure:
1. The first project, WITHOUT using GA, rank(A) is called just one time. Then, it gives a correct result of rank of matrix A which I have checked with Matlab
Here is the code and output file for the first project
Fortran short code which employed 'rank' function in main program
program main
use imsl_libraries
use linear_operators
!DEC$ OBJCOMMENT LIB:'libiomp5md.lib'
character*12 infile, outfile, plotfile,strfile
include 'comsol.f'
include 'link_fnl_shared.h'
integer i,j,k,nsol,nfinal
real*8 err(mki),fsol(mem),ginv(600,700)
integer ifile,rnk
call input
call mkcon !Build the Incidence matrix
call mklen !Build the length matrix
call mkaaa !Build A matrix
!call dlsvrr(neq,nuk,aat,meq,21,1.d-5,irank,sval,uuu,meq,www,muk)
irank=rank(aat) !att is A matrix
nsi=nuk-irank
nki=nsi+neq-nuk
write(6,9001) irank,nsi,nki
9001 format(/5x,'irank : rank of matrix A....................',t50,i3,
+ /5x,'nsi (s): degree of statical indeterminacy....',t50,i3,
+ /5x,'nki (m): degree of kinematical indeterminacy.',t50,i3)
end
Short Output file which show A matrix and calculated value of rank(A) from first project
Final A matrix
0.000E+00 0.000E+00 0.100E+01 0.000E+00 0.000E+00 0.707E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00
0.000E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00 -0.707E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00
0.100E+01 0.000E+00 0.000E+00 0.000E+00 0.707E+00 -0.707E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00
0.000E+00 0.000E+00 0.000E+00 0.000E+00 0.707E+00 0.707E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00
0.000E+00 0.100E+01 -0.100E+01 0.707E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00
0.000E+00 0.000E+00 0.000E+00 -0.707E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00
-0.100E+01 0.000E+00 0.000E+00 -0.707E+00 0.000E+00 0.000E+00 -0.100E+01 0.000E+00 0.000E+00 0.000E+00
0.000E+00 0.000E+00 0.000E+00 0.707E+00 0.000E+00 0.000E+00 0.000E+00 -0.100E+01 0.000E+00 0.000E+00
0.000E+00 -0.100E+01 0.000E+00 0.000E+00 -0.707E+00 0.000E+00 0.000E+00 0.000E+00 -0.100E+01 0.000E+00
0.000E+00 0.000E+00 0.000E+00 0.000E+00 -0.707E+00 0.000E+00 0.000E+00 0.000E+00 0.000E+00 -0.100E+01
irank : rank of matrix A................... 10
nsi (s): degree of statical indeterminacy... 0
nki (m): degree of kinematical indeterminacy 0
2. The second project, using GA, rank(A) is called THOUSANDS OF time due to searching algorithm of GA, it is needed to calculate rank of matrix for each candidate selected by GA. Then, it gives a WRONG result of rank of matrix A even for the candidate which gives identical A matrix in problem of first project
Here is the code and output file for the second project
Fortran short code which employed 'rank' function in subroutine
subroutine ChkFrcMtd
use imsl_libraries
include 'comsol.f'
integer nsi,nki,ark !irank,
real*8 uuu,www,fsval
irank=0
!call dlsvrr(neq,nuk,aat,meq,20,1.d-10,irank,fsval,uuu,meq,www,muk)
irank = rank(aat) !att is A matrix
nsi=nuk-irank
nki=nsi+neq-nuk
write(6,*) 'irank: mathematical rank of matrix A...........',irank
write(6,*) 'nsi (s): degree of statical indeterminacy......',nsi
write(6,*) 'nki (m): degree of kinematical indeterminacy...',nki
return
end
Short Output file selected from the candidate by GA which show identical A matrix to the first project with single try
Final A matrix
irank: mathematical rank of matrix A........... 12
nsi (s): degree of statical indeterminacy...... -2
nki (m): degree of kinematical indeterminacy... -2
Have you ever met this kind of phenomena?
Is there any problem with my code or imsl library?
Please help me to clarify this issue.
Please let me know if you need more information or short code for clarifying the problem.
Thank you in advance.
Xuan-Hoang.
