IMSL and going from visual studio 2012 to 2010
Brian_Murphy
New Contributor II
I have ported a working project from one computer with visual studio 2012 to another with visual studio 2010, and I'm getting a strange error from a routine named LSAME during an IMSL operation that is computing a matrix solution using overloaded operators and Harwell sparse matrices.  It looks like RESULT = A .ix. RHS.  I think the problem is in the porting, not the program.  Is there anything I should have done while porting to make it work?
I think the VS2012 system has visual fortran composer XE 2013 update 5, and the VS2010 system has update 4.  Could that be my problem?
Steven_L_Intel1
Crystal ball out for repairs. Please elaborate on what the "strange error" is.  Also, do you have the same version of IMSL installed on both computers?
Brian_Murphy
New Contributor II
Sorry about that, Steve.  I was hoping there was something really obvious I failed to do.  Here's the error message.  This happens on the statement that does the matrix solution.  There is no character variable being passed by me on that statement.
forrtl: severe (408): fort: (18): Dummy character variable 'CA' has length 1 which is greater than actual variable length 0
I don't know how to find the IMSL version.  I found a file named imslsupport.txt in the FNL folder for both systems that says w_fcompxe_imsl_2013.0.002
I have a file named w_fcompxe_novsshell_2013.6.204.exe that I could apply to the VS2010 system, but I don't have an IMSL file to go with it, or is IMSL is built into it?
Brian_Murphy
New Contributor II
I tried to install the Update 6 file, and I got a message saying I couldn't install it.  I think because my subscription has expired.
Steven_L_Intel1
You have the correct IMSL version. The IMSL installer is separate.
It simply looks as if the older compiler had a bug fixed in the newer one. I remember seeing a bug with a symptom like that a while ago. Perhaps if you turn off array bounds checking you can continue.
Brian_Murphy
New Contributor II
I have managed to install Update 5 onto the system with Update 4.  But this seems to have broken IMSL, so I will try to reinstall IMSL.  Now where did I put that darned thing?
Brian
Brian_Murphy
New Contributor II
I reinstalled IMSL, and that didn't help.
error #5102: Cannot open include file 'link_fnl_static.h'
error #7002: Error in opening the compiled module file. Check INCLUDE paths.
It doesn't make any sense that installing update 5 would mess this up, as well as reinstalling IMSL didn't fix it.  There must be something really screwed up.  Where do I "check include paths".  I've been looking, but I can't find this.
Brian_Murphy
New Contributor II
Thanks again, Steve.  It was Tools/Options/Intel Composer XE/Visual Fortran/Compilers/ etc...........
It now builds and runs, but I'm still getting exactly the same error at exactly the same place.  Darn.
The only error that appears during building is this:
Error 3  general error c101008d: Failed to write the updated manifest to the resource of file "C:\Users\Brian\Documents\Visual Studio 2010\Projects\TRC-2013\Lateral Torsion Coupling\DLLUserTor\DLLUserTor\Debug\DLLUserTor.dll". The parameter is incorrect. mt.exe
A new file DLLUserTor.dll did get created during the build.  I get feeling this isn't important.  Or is it?
Later tonight I will double check the arrays being passed to the .ix. operation.  I think I'm running a case that ran fine on the other system, but I will make sure about that.
Steven_L_Intel1
The mt.exe error may or may not be important, but it is odd. I have seen a variation where it complains that the EXE is open by another user, but the "parameter is incorrect" suggests a syntax error on the command line used to run mt, and that should be generated automatically. Can you attach a ZIP of the buildlog.htm?
You're getting that 408 character length error? Is there a traceback?
Brian_Murphy
New Contributor II
The buildlog is attached.
The following is what appears in the console window:
Image              PC        Routine            Line        Source
libifcoremdd.dll   003E1A70  Unknown               Unknown  Unknown
libifcoremdd.dll   003CDB26  Unknown               Unknown  Unknown
libifcoremdd.dll   0034EF12  Unknown               Unknown  Unknown
libifcoremdd.dll   0034F683  Unknown               Unknown  Unknown
XLTRC2.exe         017564C6  _LSAME                     37  lsame.f
XLTRC2.exe         01A5104F  Unknown               Unknown  Unknown
XLTRC2.exe         01A49ACB  Unknown               Unknown  Unknown
XLTRC2.exe         0192F5BB  Unknown               Unknown  Unknown
XLTRC2.exe         01859F6B  Unknown               Unknown  Unknown
XLTRC2.exe         0146B8DE  _DNSIMP                   238  Arnoldi.f90
XLTRC2.exe         01468035  _ARNOLDI_EIGS              60  Arnoldi.f90
XLTRC2.exe         00FC9E9F  _GET_TRANSFORM_T3         260  Transf.f90
XLTRC2.exe         0161E5DF  _REDUCE_MATRIX             20  ReduceMat.f90
XLTRC2.exe         01C201D3  Unknown               Unknown  Unknown
XLTRC2.exe         01799DAF  Unknown               Unknown  Unknown
XLTRC2.exe         01799BDF  Unknown               Unknown  Unknown
kernel32.dll       76563677  Unknown               Unknown  Unknown
ntdll.dll          77499D72  Unknown               Unknown  Unknown
ntdll.dll          77499D45  Unknown               Unknown  Unknown
Brian_Murphy
New Contributor II
Could it be that this problem is happening because I tried to use the visual studio 2012 .sln file in visual studio 2010?
It's a big project made by others over many years.  If I were to recreate it from scratch in vs 2010, is there some recipe for doing that?
Steven_L_Intel1
No, this has absolutely nothing to do with your Visual Studio version.
The build log you attached shows only the link step - I wanted to see the compile.
What is LSAME? Is that one of your routines? Is it a callback you pass to IMSL? Who calls it? The error is coming from LSAME, complaining about how it was called.
mecej4
LSAME is a Lapack routine -- see, e.g., http://www.netlib.org/lapack/explore-3.1.1-html/lsame.f.html . It takes two character arguments S1 and S2 of any length, and in essence returns .TRUE. if the first characters of S1 and S2 match, case ignored.
An easy fix would be to use the LSAME function available in MKL, instead of using a source version of LSAME with uncertain pedigree. See https://software.intel.com/en-us/node/522127 .
Steven_L_Intel1
Ok - I see that LSAME takes a CHARACTER*1 argument. Perhaps you're calling it incorrectly (such as not passing it a character.) IMSL is not involved.
Brian_Murphy
New Contributor II
I do not call LSAME anywhere in my code.  Line 238 in Arnoldi.f90 is the statement with the overloaded operator.
However, this project also includes LAPACK source code.  That came along with ARPACK when ARPACK was added to the project.  But this project runs on the computer with visual studio 2012.
The ARPACK code does call LSAME in hundreds of places.  I don't know what LSAME looks like in IMSL or MKL, but the one that came with ARPACK starts with this:  Maybe somehow the project as compiled with vs2010 is doing things differently than when compiled with vs2012.
      LOGICAL          FUNCTION LSAME( CA, CB )
*  -- LAPACK auxiliary routine (version 2.0) --
*     Univ. of Tennessee, Univ. of California Berkeley, NAG Ltd.,
*     Courant Institute, Argonne National Lab, and Rice University
*     September 30, 1994
*     .. Scalar Arguments ..
      CHARACTER          CA, CB
By the way.  I double checked that I'm running the code with a valid reproducible case.
Steven_L_Intel1
Where did you get the LAPACK library. Did you build it yourself? The traceback shows a bunch of intermediate calls without traceback info. LSAME was compiled with /check:bounds. Maybe there's a bug in the compiler used to compile it, or maybe there's a bug in the call.
Brian_Murphy
New Contributor II
Another weird thing started happening about the same time I did the intel fortran update.  I have a breakpoint set at line 238 with the overloaded operator.  Before, trying to step past that line would immediately trigger the LSAME error.  Now, however, I also get prompted that there is no disk in the CD drive.  Well, that was yesterday.  Today I'm not getting that prompt, but I still get the LSAME error.
Boy, is this fun.
Brian_Murphy
New Contributor II
LAPACK came with ARPACK.
I set a breakpoint on line 37 in my source code for LSAME, and execution did go there from the line 238.  Right before the error happens at line 37, the call stack shows this:
> XLTRC2.exe!LSAME( , CHARACTER(1)  CA, CHARACTER(1)  CB,  .tmp..T5__V$7)  Line 37 Fortran
  XLTRC2.exe!_dgscon()  + 0x6f bytes C
  XLTRC2.exe!_c_fortran_dgssv()  + 0x76b bytes C
  XLTRC2.exe!_D_F95_COND()  + 0x5d9 bytes
  XLTRC2.exe!_SPARSE_LINEAR_OPERATORS_mp_D_HBC_SPARSE_SOLVE_VECTOR.()  + 0x131f bytes
  XLTRC2.exe!DNSIMP( , REAL(8)  D, REAL(8)  V, REAL(8)  RESID, INTEGER(4)  NX, INTEGER(4)  NEV, INTEGER(4)  NCV, INTEGER(4)  IERR, LOGICAL(4)  RVEC, TYPE(D_HBC_SPARSE)  A, TYPE(D_HBC_SPARSE)  M)  Line 238 + 0x432 bytes Fortran
Brian_Murphy
New Contributor II
I went back to my old computer with vs2012 and set a breakpoint on that same line in LSAME, and the code ran fine from start to finish without ever stopping there.
Does this mean the codes are getting built differently?
Steven_L_Intel1
Ok, this is weird.
IMSL is doing some internal calls to SuperLU routines - _dgscon is in IMSL, but it does not call LSAME. IMSL has its own version of LSAME, but if you supplied one it would override it. These should have the same interfaces, though.
I'm wondering if the stack got corrupted somewhere, but I don't see any obvious points how.
Here's something to try. Instead of linking to the static IMSL, link to the "shared" (DLL) IMSL (include "link_fnl_shared.h") and see if the behavior changes. You can also disable array and string bounds checking for the compile of LSAME (if you're not using the DLL IMSL) - try that second.
