29434 Discussions
IVF and in-place upgrade from XP to 7 64-bit.
Greynolds__Alan
I just did and in-place upgrade of my iMac's BOOTCAMP partition from Windows XP Pro to Windows 7 64-bit Pro using Laplink's PCmover Upgrade Assistant. It went pretty well with my original IVF installation ending up in the "Program Files (x86)" directory. I only run from the command prompt so is therea simpler way to resetup IVF under these conditions without doing a full reinstall?
Al
TimP
If you want 64-bit compilation, you will need to add C++ X64 support to your visual studio, unless you are using the VS shell or equivalent. Assuming you still have the program files (x86)\intel\compiler\download directories, you can start the setup.exe for the version you installed previously (probably only 32-bit?), and modify or repair.
