IVF doc error? TYPE
jimdempseyatthecove
Index:
TYPE | TYPE Statement (Derived Type)
In the following example, a and b are both variable arrays of derived type pair:
 TYPE (pair)
   INTEGER i, j
 END TYPE
 TYPE (pair), DIMENSION (2, 2) :: a, b(3)
Is that correct? If so, explain further.
Jim Dempsey
No, that first TYPE(pair) is incorrect. I will let the writers know - thanks.
I also don't like the use of b(3) in the declaration that has DIMENSION(2,2). It's legal but bad style in my opinion.
jimdempseyatthecove
Then what is b?
(1:3) or (1:2,1:2,1:3)
Jim Dempsey
(1:3).
The type declaration statement also specifies the attributes whose keywords appear in the attr-spec, except that the DIMENSION attribute may be specified or overridden for an entity by the appearance of array-spec in its entity-decl , and the CODIMENSION attribute may be specified or overridden for an entity by the appearance of coarray-spec in its entity-decl .
