faulty compiler error #6526
WSinc
This is a simplied version of something I submitted earlier.
program Console11
    integer i1,i2,i3,i4,j
    do 10 i1=1,10
      do 10 i2=1,10
        if(i2==i1)go to 10
        do 20 i3=1,10
          if(i3.eq.i2 .or. i3.eq. i1) go to 20
          do 20 i4=1,10
            if(i4.eq.i3.or. i4.eq.i2 .or. i4 .eq.i1)go to 20
            j=i1+i2+i3+i4
20 enddo
10 enddo
    end program
This wont compile, unless I add another enddo line, i.e.
that I use Do 30, I4=1,10
I think the presence ot the IF statements causes the problem.
I want to get Unique values of i1,i2,i3, and i4
Your program is faulty, not the compiler. The compiler's error message is exactly on target, though it's highlighting the wrong line
t.f90(7): error #6526: A branch to a do-term-shared-stmt has occurred from outside the range of the corresponding inner-shared-do-construct.   [20]
          do 20 i4=1,10
When you have shared DO termination (an obsolescent feature), the termination belongs to the innermost loop. The line:
is part of the outermost loop and therefore a branch into the inner loop is not allowed.
Don't use shared DO termination. Instead of GOTO, consider  CYCLE with a labeled loop.
mecej4
billsincl wrote:
I want to get unique values of i1,i2,i3, and i4
Your specification is incomplete. Do you want just one quartet of distinct integers between 1 and 10? Or do you want to list all such quartets? If the latter, here is code that does it without using labels (caution: there are thousands of -- 10*9*8*7, to be precise -- lines printed out!).
If you wish to rule out permutations, you need to modify the code.
The obvious solution, [1, 2, 3, 4] has the virtue that the items add up to 10, the upper bound of the range of values permitted.
program quartet
implicit none
integer :: i1,i2,i3,i4
logical :: used(10) = .false.
do i1 = 1, 10
   used(i1) = .true.
   do i2=1,10
      if (used(i2)) cycle
      used(i2) = .true.
      do i3 = 1, 10
         if (used(i3)) cycle
         used(i3) = .true.
         do i4 = 1, 10
            if (used(i4)) cycle
            write(*,'(4I4)')i1,i2,i3,i4
         end do
         used(i3) = .false.
      end do
      used(i2) = .false.
    end do
    used(i1) = .false.
end do
end program
jimdempseyatthecove
program Console11
 do i1=1,10
   do i2=1,10
     if(i2==i1) cycle
     do i3=1,10
       if(i3.eq.i2 .or. i3.eq. i1) cycle
       do i4=1,10
         if(i4.eq.i3.or. i4.eq.i2 .or. i4 .eq.i1) cycle
         j=i1+i2+i3+i4
       enddo ! i4
     enddo ! i3
   enddo ! i2
 enddo ! i1
end program
Jim Dempsey
andrew_4619
Well you learn something new every, I didn't know CYCLE (and more usefully EXIT) can use a loop label to trip out of more than one level of loop nesting! Cheers!
