Ifort bug: Defined assignment not recognized
Bálint_A_
Dear Intel developer,
The ifort compiler (16.0.0 20150815) refuses to compile valid Fortran 2003 code if this contains overridden assignment in a polymorphic type. The self containing code below demonstrates the issue. The compiler stops with the error message
test.F90(59): error #6197: An assignment of different structure types is invalid.   [MYEXT1]
  pExt1 = myExt1
although an assignment operator for the polymorphic variable pExt1 is defined. Other Fortran 2003 compilers seem to have no problems with it.
Bálint
module typedefs
  implicit none
  type :: Base
  contains
    procedure :: assignFrom => Base_assignFrom
    generic :: assignment(=) => assignFrom
  end type Base
  type, extends(Base) :: Extended
    integer :: data
  contains
    procedure :: assignFrom => Extended_assignFrom
  end type Extended
contains
  subroutine Base_assignFrom(this, other)
    class(Base), intent(inout) :: this
    class(Base), intent(in) :: other
    select type (other)
    type is (Base)
      continue
    class default
      print *, "Wrong data type for Base%assignFrom"
      error stop 1
    end select
  end subroutine Base_assignFrom
  subroutine Extended_assignFrom(this, other)
    class(Extended), intent(inout) :: this
    select type (other)
    type is (Extended)
      this%data = other%data
    class default
      print *, "Wrong data type for Extended%assignFrom"
      error stop 1
    end select
  end subroutine Extended_assignFrom
end module typedefs
program test
  use typedefs
  implicit none
  type(Extended) :: myExt1
  class(Base), pointer :: pExt1
  myExt1%data = -1
  allocate(pExt1, source=myExt1)
  pExt1 = myExt1
  select type (pExt1)
  type is (Extended)
    print *, "VALUE:", pExt1%data
  class default
    print *, "Unexpected type"
  end select
end program test
Steven_L_Intel1
Thanks, we'll take a look.
FortranFan
If I recall correctly, 'polymorphic assignment' is a Fortran 2008 feature that is not yet supported by Intel Fortran.  Even when it does get supported, I think the generic resolution issue, similar to the other incident you posted (https://software.intel.com/en-us/forums/intel-fortran-compiler-for-linux-and-mac-os-x), will remain given how you put together the Base and Extended derived types.  So with polymorphic variable pExt1 declared as 'class(Base', my impression is you will still need to do along the following lines but I'm open to the possibility of being wrong about this:
program test
   use typedefs
   implicit none
   myExt1%data = -1
   select type (pExt1)
      type is (Extended)
         pExt1 = myExt1
      class default
   end select
end program test
Bálint_A_
The assignment to an allocatable polymorphic variable is indeed Fortran 2008. However, here we have an assignment to a static polymorphic variable and that is Fortran 2003, as far as I know. I can not point out the part in the standard, but I've checked it also with another commercial compiler which I have found the most reliable so far when in doubt about the standard, and it compiles the code in F2003 mode.
Also, thanks for the workaround, but that won't help in my situation, as in my application I can not know the possible types in advance. I would like to implement a general purpose container holding arbitrary extensions of a given derived type with user overridden assignments.
Steven_L_Intel1
Intrinsic assignment to a polymorphic variable is not standard F2003:
17 An intrinsic assignment statement is an assignment statement that is not a defined assignment
18 statement (7.4.1.4). In an intrinsic assignment statement, variable shall not be polymorphic, and
19 (1) If expr is an array then variable shall also be an array,
20 (2) Either variable shall be an allocatable array of the same rank as expr or the shapes of
21 variable and expr shall conform, and
(3) The declared types of variable 1 and expr shall conform as specified in Table 7.8.
However, this is defined assignment which is not so restricted.
Bálint_A_
Thank you for the clarification! I've changed the title of the thread to contain the correct wording.
Steven_L_Intel1
Escalated as issue DPD200409351. I will update this thread when there is news.
Juergen_R_R
Valued Contributor II
Apparently this thread was never updated but this is definitely fixed now in recent versions of ifort.
may_ka
Not fixed in 17.07 and 18.03
Cheers
Juergen_R_R
Wait, my check wasn't proper: apparently it _is_ fixed in ifort v19beta!
