Incorrect build order causes 'Error in opening the compiled module file'
Arthur_van_Dam
Hi all,
I've encountered a strange compilation error, which my colleagues and I cannot trace down to a user error.
Below is an isolated test problem. It contains a module mf (in mf.f90), which uses module mdm (in mdm.f90).
Unfortunately, a clean build causes mf.f90 to be compiled *before* mdm.f90, so we get:
Compiling with Intel(R) Visual Fortran Compiler XE 13.0.1.119 [IA-32]...
sbm.f90
bcm.f90
mf.f90
D:\dam_ar\scratch\build_problem\src\mf.f90(2): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [MDM]
mdm.f90
There's two more files, but they don't seem to be causing problems.
I see no cyclic dependency, so why is the compiler building mdm.f90 *after* mf.f90?
The deps are:
mf uses mdm uses sbm
and
bcm uses sbm
Here's the four file listings, all are also included in the attachment:
module bcm
use sbm
private
end module bcm
module mdm
use sbm
private
end module mdm
module mf
use mdm
end module mf
module sbm
private
end module sbm
The attachment contains the example files + vfproj+sln for a static library configuration, no user-defined compiler settings that I'm aware of.
Thanks for any help!
Arthur_van_Dam
Sorry, forgot to mention:
The error occurs in Visual Studio 2010 Version 10.0.40219.1 SP1Rel
with Intel(R) Visual Fortran Composer XE 2011 Update 11 Integration for Microsoft Visual Studio* 2010, 12.1.3534.2010
but also in:
Visual Studio 2012 (update 1) with Intel Fortran 13.0 Update 1
And also:
Visual Studio 2012 (update 5) met Intel Fortran 13.1 Update 3
Steven_L_Intel1
I can reproduce this - and don't see any reason for it. I will send this to the developers for investigation - thanks for the simple example. Issue ID is DPD200250684.
Steven_L_Intel1
The cause of this problem is that mdm.f90 has a "byte order mark" (BOM) escape sequence at the start of the file - see screenshot. This doesn't show in the source editor, but it confuses the dependency checker. The workaround is to add a blank or comment line before the MODULE line.
We will fix this for a future release, but you can edit the file to eliminate the problem for now.
mecej4
Interesting catch by Dr. Fortran! The Unix file utility, available as part of Cygwin, says this about the source files extracted from the zip file attached in a post above in this thread:
[bash]S:\lang\build_problem\src>file *.f90
bcm.f90: ASCII text, with CRLF line terminators
mdm.f90: UTF-8 Unicode (with BOM) text, with CRLF line terminators
mf.f90:  ASCII text, with CRLF line terminators
sbm.f90: ASCII text[/bash]
Steven_L_Intel1
I can't take credit for this - it was our IDE developers who figured it out.
andrew_4619
The 'best workaround' would probably be to open mdm.f90 in notepad and then do a  'save as' setting the type to ANSI and thus replacing the UTF-8 file with and ANSI version.
OR better, use 'save as' in the VS editor, that has all encoding options also....
andrew_4619
Actually ignore that last post if your file actually needs to be UTF-8 because it has not ANSI text, e.g. comments in Japanese!!!!
Arthur_van_Dam
Thank you, Steve and your team! We'll keep these encoding-rarities in mind to solve future 'mysteries' ourselves.
Steven_L_Intel1
I expect this to be fixed in Update 2.
