29487 Discussions
Incorrect output on minloc and maxloc of empty array
vzecca
!Incorrect output: must be compiled and run
program intrinsic_mmloc_4
integer, allocatable, dimension(:) :: d
integer, allocatable, dimension(:,:) :: a
integer, dimension(2) :: b
allocate (d(0))
if (maxloc (d, 1) .ne. 0) print *,'maxloc fails'
allocate (a(1, 0))
b = minloc (a)
if (any (b .ne. 0)) print *,'minloc fails'
end program
andrew_4619
andrew_4619
vzecca
Thank you, Andrew, for the suggestion.
The correct execution of the code requires opetion -assume nooldmaxminloc
which adheres to the Fortran standard.
Unfortunately the default option violates the standard.
Closing this issue.
Steve_Lionel
You can use the option -standard-semantics to change defaults that don't match the standard. In all cases, these are situations where earlier versions of the standard were silent, and the developers chose an option that conflicted with a later revision. If existing code would break, or performance would suffer significantly, the default was left the same.
See https://software.intel.com/content/www/us/en/develop/articles/intel-fortran-compiler-support-for-fortran-language-standards.html for a list of these conflicting defaults.
