Initializing double precision
h_amini
Hi there
In the following program, "a" is initialized to 0.004, but after running the code, the result is:
a= 4.000000189989805E-003 which is wrong. Then I input ".004" and got a= 4.000000000000000E-003 (right), but when I input .07 the result is a= 7.000000000000001E-002 which is again wrong.
Any comment would be very much appreciated.
Please also let me know if there is a more precise variable than double precision or not.
Many thanks
Hamid
DOUBLE PRECISION a
a=.004
1 print*,'a=',a
read*,a
go to 1
end
.004 is a "default real" (that is, single precision) constant. What you want instead is .004D0.
h_amini
Many thanks for this, but what about inputting ".07".
It's not wrong. That's the closest approximation to .07 in double precision. Most decimal fractions cannot be exactly represented in binary floating point.
I suggest reading The Perils of Real Numbers (three-part series).
TimP
Quoting - h.amini
ifort (and other Fortran 90 compilers) support a wider data type, often known as quad precision or real*16, at significant performance cost. The short introduction to this topic is in the ifort help, under Floating-point Representation.
