Initilization of Allocatble arrays ifort?
vinoth
Hi Friends
I have a module which contains two subroutines in which (first subroutine) i use the allocatable attribute to allocate the space for arrays then do some computations and deallocate them at the end. My first subroutine is called more than 1000 times. My question (problem) is when i initilize the allocatable arrays to zero i get a different result and when i don't initilize them to zero i get a different results?.
First of all is it right to initilize the allocatable arrays to zero?. I have seen some threads but iam not able to come to clear conclusion.
I am compiling it in ifort version 12.1.3 Any help is highly appreciated. Below is my code for reference
subroutine rho_z
implicit none
  integer :: i,actual_particle,nrot
  integer :: max_pos
  real    :: ord_xx,ord_yy,ord_zz
  real    :: ord_xy,ord_xz,ord_yz
  integer, dimension(:), allocatable :: index,jndex,counter
  real, dimension(:), allocatable :: value_N,value_O,ord_z
  real, dimension(:), allocatable :: local_order,help_dip
  real, dimension(3,3)            :: Q,eigen_vector_glob
  real, dimension(  3)            :: eigen_value_glob
  allocate(index   (N_particle)); allocate(local_order   (N_particle))
  allocate(value_N (N_particle)); allocate(value_O       (N_particle))
  allocate(ord_z   (N_particle))
  allocate(jndex     (maxchannel_rho));allocate(help_dip(maxchannel_rho))
  allocate(counter   (maxchannel_rho))
  index=0; jndex=0; counter=0    ! Initilizing the allocatable arrays to zero
  value_N=0.;value_O=0.;ord_z=0. ! Initilizing the allocatable arrays to zero
  local_order=0.;help_dip=0.         ! Initilizing the allocatable arrays to zero
  Q=0.;eigen_vector_glob=0.
  eigen_value_glob=0.
  ord_xx=0.0; ord_yy=0.0; ord_zz=0.0
  ord_xy=0.0; ord_xz=0.0; ord_yz=0.0
  nrot=0
  do i=1,N_particle
    actual_particle=living_particles%item(i)
    index  (i)=int((molecule(actual_particle)%z+0.5)/delta_rho)+1
    ord_z  (i)=molecule(actual_particle)%u_z
    value_N(i)=1.0
    value_O(i)=0.5*(3.*molecule(actual_particle)%u_z&
                      *molecule(actual_particle)%u_z  -1.)
  end do
  call av_add_hist(local_density,N_particle,index,value_N)
  call av_add_hist(S_local      ,N_particle,index,value_O)
  call av_add_hist(local_order_z,N_particle,index, ord_z)  !Binning the histogram order wrt wall normal
  do i=1,N_particle
    ord_xx=ord_xx+0.5*(3.*molecule(actual_particle)%u_x*molecule(actual_particle)%u_x -1.)
    ord_yy=ord_yy+0.5*(3.*molecule(actual_particle)%u_y*molecule(actual_particle)%u_y -1.)
    ord_zz=ord_zz+0.5*(3.*molecule(actual_particle)%u_z*molecule(actual_particle)%u_z -1.)
    ord_xy=ord_xy+1.5*    molecule(actual_particle)%u_x*molecule(actual_particle)%u_y
    ord_xz=ord_xz+1.5*    molecule(actual_particle)%u_x*molecule(actual_particle)%u_z
    ord_yz=ord_yz+1.5*    molecule(actual_particle)%u_y*molecule(actual_particle)%u_z
  end do
  ord_xx=ord_xx/N_particle
  ord_yy=ord_yy/N_particle
  ord_zz=ord_zz/N_particle
  ord_xy=ord_xy/N_particle
  ord_xz=ord_xz/N_particle
  ord_yz=ord_yz/N_particle
  Q(1,1)=ord_xx
  Q(2,2)=ord_yy
  Q(3,3)=ord_zz
  Q(1,2)=ord_xy
  Q(2,1)=ord_xy
  Q(1,3)=ord_xz
  Q(3,1)=ord_xz
  Q(2,3)=ord_yz
  Q(3,2)=ord_yz
  call Jacobi(Q,3,eigen_value_glob,eigen_vector_glob,nrot)
  max_pos = maxloc(eigen_value_glob,1)
  do i=1,N_particle
     local_order     (i)=molecule(actual_particle)%u_x*eigen_vector_glob(1,max_pos)+&
                         molecule(actual_particle)%u_y*eigen_vector_glob(2,max_pos)+&
                 molecule(actual_particle)%u_z*eigen_vector_glob(3,max_pos)
     help_dip (index(i))=help_dip(index(i))+local_order(i)
     counter (index(i))=counter(index(i)) + 1        !Counter for no.of particles in a bin
   !write(*,*)help_dip(i),counter(i)
  end do
  do i=1,maxchannel_rho
     jndex(i)=i
     if(counter(i).gt.0) then
     help_dip(i)=abs(help_dip(i))/float(counter(i))
    else
    help_dip(i)=0.
    endif
     !write(6,*)counter(i)
  end do
  call av_add_hist(local_dipol_or,maxchannel_rho,jndex,help_dip)    !Binning the histogram local dipolar parameter
  deallocate(index)   ;deallocate(jndex)
  deallocate(value_N) ;deallocate(value_O)
  deallocate(help_dip);deallocate(ord_z)
  deallocate(counter);deallocate(local_order)
  return
end subroutine rho_z
mecej4
Arrays as well as scalar variables, whether allocated on the heap or the stack, have to be initialized before they are used. The programmer is responsible for doing the initialization, which can be done by (i) executable statements that assign values to the variables (assignment statements, READ statements, ...), (ii) initialization by DATA statements or (iii) default initialization of user defined types.
Zero is often not a proper initialization for a newly allocated variable. For example, character variables and logical variables cannot be initialized to zero. Likewise as to the speed of light, the age of the Earth, the number of atoms in the universe, etc. The proper initialization value is quite domain dependent, and you need to judge what is proper for your application.
vinoth
@mecej4  Thank you very much for your clarification. To me it,  still looks like zero is the proper initilization for my application because i am going to keep on adding numbers between 0 to 1 in the repective array elements. Kindly, let me know if you have any comments.
Steven_L_Intel1
Just a comment on mecej4's reply - DATA statements can't be used with allocatable arrays.
vinoth, only you can determine whether 0 is the correct initial value. It seems that in this case it is. But the fundamental issue is that you are responsible for making sure that every variable is properly initialized before it is referenced.
vinoth
Thank you Steve for your inputs.
