29271 Discussions
Install Intel® Fortran Compiler (19.0.5.281)
cyjh
I want to install intel fortran compiler 19.but only the ver.2022 can be installed.
JohnNichols
Valued Contributor III
I cannot imagine a job where the current version will not with a little tweaking on the paths do all that you need.  For 19 you will need a license file, I am pretty sure.
cyjh
Thank you for your advise.
I want to run CFD simulation, and the simulation code recommends the compiler ver.19...
CFD code requires that environment variables are correctly defined:
IFORT_COMPILER19:
C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2019.5.281\windows
but  i cannnot find the same location above in latest version (ver.2022)
So i want to install compiler ver.19...
or do you have any Which location in Ver 2022 corresponds to the same directory as above?
Ron_Green
Read This thread.
Steve_Lionel
IFORT_COMPILER22
JohnNichols
There is a famous English saying about a human bean of few words, in the limit is a few, only one.  Sounds like a pure math test question.
