29594 Discussions
Installation and license problem
Tianle_Cheng
My advisor just purchased and let me install the Intel Visual Fortran compiler professional with IMSL.
After installation, I clicked the Intel license manager for Flexlm to install the license, which I obtained from my registration email,
The file is COM_W_CMP_FOR_xxxxxxxxx(hidden).lic However, when I tried to configure the FLEXlm with this file, it prompted me that "The file you slected is not a valid counted license". What's the matter?
My second question is, after installation, when I open the visual studio, it appears that I can't find any option regarding to Fortran compiler. I didn't see button as compiler, building, or run etc.
thank you!
regards,
Tianle Cheng
Steven_L_Intel1
I would suggest completely uninstalling Intel Visual Fortran and Microsoft Visual Studio. Then run the Intel Visual Fortran installer again - make sure it is w_cprof_p_11.1.046.exe and not one with _IA32 or _novsppe in its name. Let us know what happens.
Shamla_P_Intel
Quoting - Tianle Cheng
thank you!
regards,
Tianle Cheng
Greetings,
This is a single user license. The serial number can be used during the install or the license file. There is no need to configure Flexlm for a single user license. I have resend you the license file.
Please make sure the install is succesful and check if you still have the second issue reported.
Thank You
Shamla
Tianle_Cheng
Quoting - Shamla (Intel)
Greetings,
Thank You
Shamla
Hi Shamla,
Thank you for the reply. I disregard the Flexlm now. My installation process appeared to be smooth, and I can open the Visual studio software after installation. (The installation file that I downloaded is w_cprof_p_11.1.046.exe, is it correct?)The problem is, when I new a project in the Visual Studio 2008, I can't findthe Intel Visual Fortran project type.
regards,
Tianle
Kevin_D_Intel
Hi Tianle - The behavior suggests the the integrations with Visual Studio dod not install successfully. Please refer to the Knowledge Base article (here) for steps you should follow in trying to resolve this issue.
Tianle_Cheng
I followed the article instructions:
1. look to see if "Microsoft Visual C++" is listed. If it is not, reinstall Visual Studio and make sure that the Visual C++ component is installed.
I checked and I didn't see Microsoft Visual C++, I reinstalled Visual Studio but still didn't find it, what shall I do?
2. Look under Installed Products to see if "Intel Visual Fortran Compiler Integration" is listed
I didn't see this module installed either.
By the way, I have tried the VS2008repair tool, and it didn't resolve.
thanks,
Tianle
TimP
Microsoft C++ is an optional component which you must check on when revising Visual Studio installation. In addition, for 64-bit support, the X64 box under C++ must be checked.
Steven_L_Intel1
In Visual Studio, please click Help > About. Click the "Copy Info" button and paste the results into a reply here. If you are using the bundled Visual Studio 2008 Shell, you will not see Visual C+ listed.
Steven_L_Intel1
Sorry - moved this back to Licensing by accident. Will ask to get it re-moved to Fortran.
Tianle_Cheng
Hi Steve,
I hereby post the version release information as below:
Microsoft Visual Studio 2008
Version 9.0.21022.8 RTM
Microsoft .NET Framework
Version 3.5 SP1
Installed Edition: IDE Standard
Intel Visual Fortran Compiler Integration for Microsoft Visual Studio* 2008, 11.1.3466.2008, Copyright (C) 2002-2009 Intel Corporation
* Other names and brands may be claimed as the property of others.
Tianle_Cheng
So currently what would you suggest me to do?
Tianle
Steven_L_Intel1
I suggest that you continue with the steps in the article, including running the "repair" utility. You have Visual Studio 2008 Shell installed, so you won't see C++.
Tianle_Cheng
Hi Steve,
I forgot to say that I hadalready tried the repair utility, "VS2008 Repair Tool", but it didn't work unfortunately.
Tianle
Wendy_Doerner__Intel
Valued Contributor I
Hi Steve,
Tianle
Tianle,
Hi. I work with Steve who is out for a couple of days. Did the "VS2008 Repair Tool" give you any output (this can be helpful in diagnosing the source of the IDE integration problem).
From your output it does look like the IDE integration installed correctly to the VS2008 shell. What do you see when you create a project (i.e. Is there a Fortran choice at all, and if there is what error message do you get when you try to use it?).
Wendy
Attaching or including files in a post
Tianle_Cheng
Tianle,
Wendy
Hi Wendy,
You might see the interface of VS2008. When I new a project, there's nothing related to Visual Fortran. I installed the VS2008 repair tool and it seems to be successfully installed, no error message, but it didn't take effect.
Tianle
Steven_L_Intel1
Steven_L_Intel1
Did you run the repair tool? It doesn't "install".
I suggest that after you uninstall Intel Visual Fortran that you delete the "Intel Fortran" folder under Microsoft Visual Studio 9.0, and then reinstall.
