Add the attached .lib file to your project. Use this interface:
[cpp]INTERFACE FUNCTION HtmlHelp (hWndMain, lpszHelp, uCommand, dwData) USE ifwinTY integer(BOOL) :: HtmlHelp ! BOOL !DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'HtmlHelpA' :: HtmlHelp integer(HANDLE) hWndMain ! HWND hWndMain !DEC$ ATTRIBUTES REFERENCE, ALLOW_NULL :: lpszHelp character*(*) lpszHelp ! LPCSTR lpszHelp integer(UINT) uCommand ! UINT uCommand integer(ULONG_PTR) dwData ! ULONG_PTR dwData END FUNCTION END INTERFACE [/cpp]
and then your procs will need to process WM_HELP in the message loop handler:
[cpp]CASE (WM_HELP) rval = HtmlHelp (ghwndmain, helppathname, HH_DISPLAY_TOPIC, NULL) [/cpp]
Thanks Paul,
Where are HH_DISPLAY_TOPIC and other such constants defined?
Thanks Paul,
[cpp]! HTML help command flags INTEGER, PARAMETER :: HH_DISPLAY_TOPIC = #0000 INTEGER, PARAMETER :: HH_DISPLAY_TOC = #0001 INTEGER, PARAMETER :: HH_DISPLAY_INDEX = #0002 INTEGER, PARAMETER :: HH_DISPLAY_SEARCH = #0003 INTEGER, PARAMETER :: HH_KEYWORD_LOOKUP = #000D INTEGER, PARAMETER :: HH_DISPLAY_TEXT_POPUP = #000E INTEGER, PARAMETER :: HH_CLOSE_ALL = #0012 [/cpp]
Thanks again! Everything works fine now.
Uh Oh. I spoke too soon. I have got the 32-bit version to work but the 64-bit configuration will not link. "Unresolved external symbol HtmlHelpA". Does the interface need some tweaking for 64-bit applications?
function HtmlHelpA (_HtmlHelpA@16) is realized in file 'hhctrl.ocx'. Try to
search similar file.
I don't know why in Fortran the names of dlls is hidden from user.
In Delphi for example you can make so:
[delphi]function HtmlHelp(
HwndCaller: hwnd;
pszFile: string;
uCommand: integer;
dwData: integer): hwnd; stdcall; external 'hhctrl.ocx'
name 'HtmlHelpA';
[/delphi]
I don't work in 64bit, but I suspect that htmlhelp.lib may only contain 32-bit versions of the API functions, so that when your code has flexible defines such as INTEGER(HANDLE) which automatically track 32/64 bits, your calling code's Interface will then differ from the actual library routine. You will probably have to locate a 64-bit version of the library (which I am unable to supply).
C:Program FilesMicrosoft SDKsWindowsv6.0ALibx64
I am using Windows 7 (64 bit version)and the latest Intel Fortran on top of Microrosft Visual Studio 2008.
I have thesame problem of not being able to link my project because of the HtmHelpA missing.
I need further information about how to link my project successfully.
Can you help ?
f8
I would like to reproduce the question and problem of "tvinni". The existing HtmlHelp.lib, as it is, cannot be linked to routines compiled using the x64 platform. Do you know about any 64 bit version of this library or about some other possibility how to solve this problem?
Tomas
Bumping and old thread.... I have just made some tests building an application that builds and runs ok in x32 to x64. A few problems have been fixed but I have still have:
"error LNK2019: unresolved external symbol HtmlHelpA referenced in function CADHLP".
I have the x64 htmlhelp.lib (it is in the sdk that comes with VS2010 shell) and for belt and braces I added htmlhelp.lib to the linker additional dependancies and also added the libary path to additional library directories. I don't think finding the libary is a problem it is an issue with the INTERFACE I think. The interface is like Pauls' which is the #2 in this thread. Any ideas what I need to do? I have tried with an without the 'decoration' but for what its worth I don't think the X64 lib has underscores and @bytecount pre and post name. I have attached the lib header dumpbin if anyone can interpret it.
Any help would be greatfully appreciated. Andrew
You need to look closer at what you're doing to link - the routine by that exact name is in htmlhelp.lib for x64. Are you sure you're linking to the x64 library?
I just added the libary as a file in my project and it links now so a guess my settings are wrong. I will look at my project setings again....
Infact I have looked I think the problem was there was previously a x32 htmlhelp.lib file sat in my source/project folder. Having remove the lib as a project file deleted this local library file it now links OK in x32 and x64.
Thanks for pointing me in the right direction!
