The attached file causes the compiler to die at -O2, but it compiles fine at -O1. I've include a compile script and the verbose output as well as the source.
I don't see any problem with the current intel64 compiler, on an Ivy Bridge platform. I didn't keep 2 versions back. It might be more meaningful if you would use a specific architecture option, since you didn't specify your platform, and be more specific about "die."
I'm using Sandy Bridge. I tried -xAVX and that did not have any impact on the problem. By "die", I meant the error shown at the end of the compile.log file:
: catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for set_periodic_rot.F (code 1)
I found a workaround for the issue. Just move the reference to ipvmjob outside the innermost loop and -O2 then works.
I can reproduce this in 13.1.1 but not in the current update, 13.1.2 (Update 4)
