Integration Library Routine
pas1359
Under VAX FORTRAN77 there was a library routine for integration named "HSPRBL". Is there a similar rountine that I can call out using Visual FORTRAN and what is it? Thanks.
There was no such routine in the VAX Fortran product. I can't find any references to such a routine in the various libraries that I can think of. You may want to see if the IMSL libraries, in Visual Fortran Professional Edition, have something that will work for you.
Steve
pas1359
Are there any Numerical Integration Routines as part of the Visual Fortran Library that I can call out in a Program or do I have to generate my own? The VAX which I still use on occasions, does interpret the "HSPRBL" call out in the Program as an Integration routine. I am asking the question, because I would like to transfer the VAX program to Visual Fortran.
If you can call a HSPRBL routine on the VAX, it's because you're linking against some non-Digital/Compaq library that provides it. I suggest checking a link map to see where it comes from.
I suggest you look at the IMSL F90MP and FNL documentation at http://www.vni.com/products/imsl/functionality.html to see if there's a routine that meets your needs. I'm not a mathematician, so I don't quite know what to look for. (I saw some reference to "elliptical integration"..) If you find a routine in these libraries, it would be in Visual Fortran Professional Edition's IMSL libraries.
Steve
pas1359
Thank you
Jugoslav_Dujic
Valued Contributor II
FWIW, searches on IMSL, Netlib and Google yielded zero results :-(.
Intel_C_Intel
I assume you mean numerical integration, or quadrature. If so, IMSL MATH library, chapter 4 will probably do.
llynisa
If you want to integrate a function that is specified numerically by a set of unequally-spaced data points, the NAG library D01GAF routine uses a Gill & Miller third-order finite difference method. I have developed an equivalent version.
Alan
gfthomas8
Alan:
Any chance of me acquiring your implementation of the Gill-Miller approach?
TIA,
Gerry T.
[email protected]
llynisa
Gerry,
I have sent you a copy of my Gill & Miller function Integdata(x,y,n,errest,ierr). If anyone else would like a copy, ask me at [email protected]
Alan
