29386 Discussions
Integration of Fortran with Visual Studio Enterprise 2017/2019
Kolacinski__Richard
I've been trying to get Parallel Studio XE 2020, Update 1, Cluster Edition to integrate with Visual Studio, Enterprise 2017 and/or 2019 (versions 15.9.14 and 16.5.4, respectively) but, try as I might, nothing shows up in Visual Studio.  Both version of Visual Studio have been installed with the Desktop development with C++ Workload.  The Visual Fortran installer, parallel_studio_xe_2020_update1_cluster_edition_setup.exe, ran to completion, including addition of the integration components for both versions of Visual Studio.  I've tried uninstalling and reinstalling both Visual Fortran as well as the two versions of Visual Studio.  I've tried the installation with only a single version of Visual Studio installed, I've tried the trouble shooting steps given in the article https://software.intel.com/en-us/articles/troubleshooting-fortran-integration-issues-with-visual-studio to no avail (the installed versions of Visual Studio are the Enterprise Editions for 2017 and 2018, the libraries VFAVWin.dll, VFHieEditor.dll, VFProj.dll, and VFProjConvert.dll are present in both the C:\Program Files (x86)\Common Files\Intel\shared files\VS Integration\VS15\Intel Fortran\VFPackages\ and C:\Program Files (x86)\Common Files\Intel\shared files\VS Integration\VS16\Intel Fortran\VFPackages\ directories (file versions 19.1.55.15 and 19.1.55.16, respectively), and I've repaired the VS 2019 integration via:
cd %CommonProgramFiles(x86)%\intel\shared files\VS Integration\VS16\Intel Fortran\VFPackages
integrate.bat “<VsInstanceDir>\Common7\Tools\”  /u
and VS 2017 via the above, mutatis mutandis.  The integrate.bat file ran successfully for both the unregister and register steps.  Still nothing appears in either version of Visual Studio.  I'm at my wit's end.  Any help would be greatly appreciated.
Steve_Lionel
In Visual Studio (either one), click Help > About, then Copy Info. Paste the result into a reply here. This may provide some helpful information.
Kolacinski__Richard
I forgot to mention that nothing shows up in the installed products list either.  In any case, here's the info:
Microsoft Visual Studio Enterprise 2019
Version 16.5.4
VisualStudio.16.Release/16.5.4+30011.22
Microsoft .NET Framework
Version 4.7.03190
Installed Version: Enterprise
Visual C++ 2019   00435-60000-00000-AA891
Microsoft Visual C++ 2019
ADL Tools Service Provider   1.0
This package contains services used by Data Lake tools
ASA Service Provider   1.0
ASP.NET and Web Tools 2019   16.5.236.49856
ASP.NET Web Frameworks and Tools 2019   16.5.236.49856
For additional information, visit https://www.asp.net/
Azure App Service Tools v3.0.0   16.5.236.49856
Azure Data Lake Node   1.0
This package contains the Data Lake integration nodes for Server Explorer.
Azure Data Lake Tools for Visual Studio   2.4.5000.0
Microsoft Azure Data Lake Tools for Visual Studio
Azure Functions and Web Jobs Tools   16.5.236.49856
Azure Stream Analytics Tools for Visual Studio   2.4.5000.0
Microsoft Azure Stream Analytics Tools for Visual Studio
C# Tools   3.5.0-beta4-20153-05+20b9af913f1b8ce0a62f72bea9e75e4aa3cf6b0e
C# components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Common Azure Tools   1.10
Provides common services for use by Azure Mobile Services and Microsoft Azure Tools.
Cookiecutter   16.5.20041.1
Provides tools for finding, instantiating and customizing templates in cookiecutter format.
Fabric.DiagnosticEvents   1.0
Fabric Diagnostic Events
IntelliCode Extension   1.0
IntelliCode Visual Studio Extension Detailed Info
Microsoft Azure HDInsight Azure Node   2.4.5000.0
HDInsight Node under Azure Node
Microsoft Azure Hive Query Language Service   2.4.5000.0
Language service for Hive query
Microsoft Azure Service Fabric Tools for Visual Studio   16.0
Microsoft Azure Stream Analytics Language Service   2.4.5000.0
Language service for Azure Stream Analytics
Microsoft Azure Stream Analytics Node   1.0
Azure Stream Analytics Node under Azure Node
Microsoft Azure Tools   2.9
Microsoft Azure Tools for Microsoft Visual Studio 2019 - v2.9.30207.1
Microsoft Continuous Delivery Tools for Visual Studio   0.4
Simplifying the configuration of Azure DevOps pipelines from within the Visual Studio IDE.
Microsoft JVM Debugger   1.0
Provides support for connecting the Visual Studio debugger to JDWP compatible Java Virtual Machines
Microsoft Library Manager   2.1.25+gdacdb9b7a1
Install client-side libraries easily to any web project
Microsoft MI-Based Debugger   1.0
Provides support for connecting Visual Studio to MI compatible debuggers
Microsoft Visual C++ Wizards   1.0
Microsoft Visual Studio Tools for Containers   1.1
Develop, run, validate your ASP.NET Core applications in the target environment. F5 your application directly into a container with debugging, or CTRL + F5 to edit & refresh your app without having to rebuild the container.
Microsoft Visual Studio VC Package   1.0
NuGet Package Manager   5.5.0
NuGet Package Manager in Visual Studio. For more information about NuGet, visit https://docs.nuget.org/
ProjectServicesPackage Extension   1.0
ProjectServicesPackage Visual Studio Extension Detailed Info
Python   16.5.20041.1
Provides IntelliSense, projects, templates, debugging, interactive windows, and other support for Python developers.
Python - Conda support   16.5.20041.1
Conda support for Python projects.
Python - Django support   16.5.20041.1
Provides templates and integration for the Django web framework.
Python - IronPython support   16.5.20041.1
Provides templates and integration for IronPython-based projects.
Python - Profiling support   16.5.20041.1
Profiling support for Python projects.
Snapshot Debugging Extension   1.0
Snapshot Debugging Visual Studio Extension Detailed Info
SQL Server Data Tools   16.0.62003.05170
Microsoft SQL Server Data Tools
Test Adapter for Boost.Test   1.0
Enables Visual Studio's testing tools with unit tests written for Boost.Test.  The use terms and Third Party Notices are available in the extension installation directory.
Test Adapter for Google Test   1.0
Enables Visual Studio's testing tools with unit tests written for Google Test.  The use terms and Third Party Notices are available in the extension installation directory.
ToolWindowHostedEditor   1.0
Hosting json editor into a tool window
TypeScript Tools   16.0.20225.2001
TypeScript Tools for Microsoft Visual Studio
Visual Basic Tools   3.5.0-beta4-20153-05+20b9af913f1b8ce0a62f72bea9e75e4aa3cf6b0e
Visual Basic components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Visual F# Tools 10.8.0.0 for F# 4.7   16.5.0-beta.20181.6+85af456066acd4e76d2bc7821b44a325e46f2fca
Microsoft Visual F# Tools 10.8.0.0 for F# 4.7
Visual Studio Code Debug Adapter Host Package   1.0
Interop layer for hosting Visual Studio Code debug adapters in Visual Studio
Visual Studio Container Tools Extensions (Preview)   1.0
View, manage, and diagnose containers within Visual Studio.
Visual Studio Tools for CMake   1.0
Visual Studio Tools for Containers   1.0
Visual Studio Tools for Kubernetes   1.0
Thanks!
Steve_Lionel
I have no idea, then. You are going to need to get Intel support directly involved. https://supporttickets.intel.com/?lang=en-U
Kolacinski__Richard
Thanks, I appreciate your time.
