Intel Fortran 2024.2
JohnNichols
Geschätzter Beitragender III
2.946Aufrufe
DO not install the new version, VS 2022 does not recognize IFX only IFORT.  IE you cannot select it.
You have to uninstall all previous versions otherwise VS 2022 gets stuck on 2024.1.
I am going to try a clean install.
1 Lösung
Devorah_H_Intel
2.645Aufrufe
@JohnNichols
  • For the oneAPI 2024.2 release, the Microsoft Visual Studio validated versions are the same as for oneAPI 2024.1:
    • up to Visual Studio 2022   version 17.9.2
    • up to Visual Studio 2019   version 16.11.34
See Intel® Compilers Compatibility with Microsoft Visual Studio* and Xcode*
Please be aware of this when updating Visual Studio.
It is all documented in the Release Notes
and Intel® Compilers Compatibility with Microsoft Visual Studio* and Xcode*
Lösung in ursprünglichem Beitrag anzeigen
9 Antworten
JohnNichols
2.938Aufrufe
No ifx compiler.  Stock standard VS 2022.
mecej4
Geehrter Beitragender III
2.886Aufrufe
With Microsoft Visual Studio 2022 Version 17.8.3 on Windows 11, I see both IFx and IFort in the property->general page (see attached screenshot). I have 2024.2.0 of IFx and 2021.13.0 of Ifort.
andrew_4619
2.855Aufrufe
John will no doubt be using 17.10.3 released on June 18th 2024. Which comes after the release of the current versions of IFX/IFORT. From experience that is always a risky thing to do and should be avoided if at all possible. I appreciate if you are a new user you can only download what is available, one reason why I download the full installer and keep it until I deem it superseded. I am current running 17.0.5 and have no issues.
I will note the OneAPI release notes say the support VS2022 but it doesn't say what sub-levels were tested which is not so helpful.
JohnNichols
2.802Aufrufe
Mea culpa: - I need to switch to a 64 bit environment for the old Fortran program, then exit and restart VS and IFX is there.
JohnNichols
2.797Aufrufe
Andrew:  only IFORT works on the latest VS 2022 Preview.    You have to have a set formula when working in multiple languages on multiple computers some which will run W11 and some that will not.  I choose to stay up to date on all software, the one that causes the most problems is Windows 11 on some of the NUC 11 computers, but it is more that they give problems with motherboards and video than Windows, but it shows up in updates that brick the computer.  My old NUC6's just keep running, whereas 2 NUC 11's from 5 are dead after 2 years.
As I install W11 often you can only install the latest VS release, the others are not available.
In all things compromise is needed.  Pity about the NUC11's there are some duds there.  I am about to travel 1200 miles to replace one.
Devorah_H_Intel
2.645Aufrufe
Can you update your original post with this info?
prop_design
Neuer Beitragender II
2.737Aufrufe
this has always been my experience. as a course of habit i always uninstall visual studio and intel fortran. then reinstall the current versions. after that, i don't update either of them. i have had instances where i had to completely reinstall windows because of bad intel fortran installs. i don't know what goes wrong. but it has happened to me several times. i dread updating intel fortran.
Steve_Lionel
2.674Aufrufe
As John realized, he was in a 32-bit build environment where ifx is not available.
Devorah_H_Intel
2.646Aufrufe
@JohnNichols
Antworten
