29279 Discussions
Intel Fortran90 install 10.0 license error
mohshee
I am trying to install the 10.0 compiler on a 64 bit CPU (Ubuntu Fiesty Fawn OS). As soon as I try to install the compiler i get booted out by a single error message:
> ./install.sh
ERROR: Problem encountered executing CHKLIC_32_64 utility located here:
/home/mohshee/downloads/l_fc_p_10.0.023_intel64/data/chklic.em64t
The CHKLIC_32_64 program data/chklic.em64t requires these libraries:
not a dynamic executable
I cannot figure out what is wrong. I've been combing through forums for a while now. The file 'data/chklic.em64t' is indeed a binary executeable. I have placed the correct license file in /opt/intel/licenses/
Any ideas??
Thanks, Shay
Well, first of all, Ubuntu is not supported by the 10.0 compiler. That aside, we recently discovered a problem with x64 Ubuntu that prevents the 10.0 compiler from working, and I think it's exactly what you encountered. This is an Ubuntu bug and we're in communication with the Ubuntu developers about it.
mohshee
Thanks for the update. I was pretty confused.
I learned a bit more and found that the error you're seeing is not the one I was thinking of, but that version of Ubuntu is still problematic.
j4play
i was having the exact same problem.
installing lib32gcc1 fixed this for me.
