I noticed that I have a bunch of IVF Fortran compiler versions listed in my Visual Studio options that are no longer installed on my system after installtion of updates. Is there a way to delete these from the list of compiler version in the options menu?
Haje
Haje
Start > Run. Type REGEDIT, click OK
Click on + symbol next to the following names, in order:
- HKEY_LOCAL_MACHINE
- Software
- Intel
- Compilers
- FORTRAN
Oh, be aware that if you install an update to 10.0, it does NOT install any previous updates. You must remove those separately if desired.
Steve,
thanks the registry edits did the trick!
Haje
Haje
Good. Starting with version 10, uninstalling an old version is supposed to remove the entry for that version.
