Intel Parallel Studio updates - disk bloat
jim_b_4
I fired up WinDirStat to check my disk space allocation.  Noted a pretty large allocation of 5 nearly identical blocks. Turns out that they were all Intel(R) Parallel Studio XE 2019 versions.  The base, plus updates 1-5 (missing update 2, for some reason).  Pic attached, showing identical blocks.
I only use the latest version, so can I delete everything except Update 5 (the latest)?
This is neither critical nor trivial: it's about 38Gb of wasted space.
Steve_Lionel
Yes, you can remove the older versions. I really wish the installer would ask if you want to do that - some people like having multiple versions installed, some don't.
jim_b_4
Steve, Thanks. I kind of realized I'd asked a wimpy question: I could have investigated this myself.  In fact, I did, and I found the same thing that you said: I deleted the previous 4 versions and then could run (for example) psxevars.bat Intel64 from the revision 5 directory.  This at least tells me that there is something working.
I think your idea of an option for a "clean" (remove earlier versions) install would be a big improvement.  I think a lot of people (like me) are sitting around with 40 extra Gb of disk usage that's not needed and they don't even know it. And 40Gb extra bandwidth and storage needed for B/U. Every backup!  BTW, is it just me that's misinterpreting things, or have we completely given up on efficient (disk usage, memory usage) programming?   [Curmudgeon, stroking his gray beard: "Back in MY day..."]
On other thing I'd like to see is a really simple test.bat.  Maybe it's just
ifort helloworld.f
helloworld
But this would at least verify the install.
Anyway, thanks very much for the help.  Stay safe and healthy!
jim b
"Programmers Leading the Way: Socially Isolating Way Before It Was Popular"
Steve_Lionel
What I do after an install is create a console application using the "sample source code" option, build and run it. That tells me that not only the compiler, but the VS integration works. One could test the debugger, too. Just a command line build doesn't test enough, and that's the most reliable part of the install.
jim_b_4
Arghhh!   I wanted to upload the 2020 version.  Apparently I'm not smart enough to figure out the licensing scheme.  That, or my network sucks.  I have an educator license.  I put it in.  I get:
Failed to download installation files, possibly due to a network connection problem. Retry or cancel installation
I think I'll be forced to use MS C++   :>|
Steve_Lionel
That's not a licensing issue. I suggest downloading the full installer rather than the small one that itself downloads pieces, as that seems to be less reliable.
Ron_Green
Later last week there was a glitch in our download servers.  It manifested in the error you described.  It's fixed, but for about a day downloads were unreliable.
jim_b_4
Ah, then it wasn't me...  I'll try again.  Thanks.
