29277 ディスカッション
Intel SGX SDK and PSW installation error (Error 2 during make sdk_install_pkg)
Prince_Khatri
ビギナー
469件の閲覧回数
Hello everyone,
I’m trying to install the Intel SGX SDK and PSW in one of our college lab machines as part of a project.
  • Hardware: Intel Core i7 9th Gen (SGX compatible)
  • BIOS: SGX enabled
  • OS: Ubantu 22.04 LTS
The issue I’m facing:
  • The command make preparation runs successfully without errors.
  • But when I run make sdk_install_pkg, I keep getting the same Error 2 repeatedly.
I have attached a copy of my terminal output (with line numbers for the commands I ran) to help illustrate the issue.
Could anyone please guide me on how to resolve this installation problem or suggest what I might be missing?
Thanks in advance for your help!
0 件の賞賛
1 返信
jimdempseyatthecove
名誉コントリビューター III
379件の閲覧回数
>>as: unrecognized option '-mlfence-after-load=yes'
...google search...
In summary, when encountering mlfence-after-load errors:
  • Check your binutils version. Ensure it's modern enough to support the flags you are using.
Jim Dempsey
返信
