- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Intel Visual Fortran Composer XE 2013 (compiler version 13.0, MKL version 11.0) is now available at the Intel Software Development Products Registration Centert! Among the new features is support for Visual Studio 2012.
Enjoy!
링크가 복사됨
12 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Abhi, I am not exactly sure what you are saying. There is a Windows bug where if the PATH is extended past some non-deterministic length, Windows will actually delete the contents of PATH the next time you log in. We've discussed this with MS and put a warning message in the installer if it looks as if it might be a problem. What happened to you?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Steve
Yes, it's the Window's path.
I did not see a warning message; at least there wasn't an "alarming pop-up". I am going to try to install again (with path variables restored) and see what happens.
Abhi
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I suggest going through PATH and removing any unnecessary entries. For example, if you've installed the 2013 product, take out any entries from the 2011 product as they are superfluous.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Steve,
I downloaded the novsshell version using the download manger. However when I try to run it, I get the message "Error while extracting file C:\Program Files (x86(\Intel\Download\f_studio_xe_2013_novsshell_setup\installs\cpro\installs\1033\w_cpromkl_intel64_11.0.0.089\data1.cab Zlib library error (data error).
Is there a problem with the file on the server, or does this mean that even using the download manager, my copy is corrupted?
David
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Steve,
I would like to read the release notes from http://software.intel.com/en-us/articles/intel-fortran-composer-xe-2013-release-notes/, but the access is denied to me although I'm logged in?
The readme at http://software.intel.com/en-us/articles/intel-visual-fortran-composer-xe-2013-for-windows-initial-release is not much detailed and the information is a little bit confusing: Why is the static library of OpenMP not provided anymore and why is Intel® Parallel Debugger Extension also no longer provided? Some more information would be nice.
Kind regards,
Johannes
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I have problems with the XE 2013 Release Notes, too.
I can access the XE 2011 Release Notes successfully.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Sorry about all the site issues - we did a lot of testing but new problems popped up when we went live. I know about the release notes article - I have attached them here and hope you can read it here. Also, the site errors are making it difficult for me to participate, so please be patient.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thank you Steve for providing the release notes.
Am I right, that due to the lost of the possibility to link the OpenMP lib statically I have to install the corresponding redistributables on every computer my program should work every time I update my Compiler? Or will the libs be compatible from initial release of XE 2013 to let's say 2013 update 2?
Kind regards,
Johannes
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
When you distribute a new version of your program, you should make sure that the Intel library DLLs are at least as new as what you built and tested against. We don't promise old runtime libraries work with newly-compiled code.
