Intel compiler misleading HOST and USE association to arrays in submodules?
Daniel_Dopico
1>D:\temp\Fallo_compilador2\restricciones.f90(33): error #7986: A use associated object that has the PROTECTED attribute shall not appear in a variable definition context.   [PROTREALVECT]
The mentioned error is obtained with the following piece of code in an Intel Parallel Studio XE 2017 Update 5 and Intel Parallel Studio XE 2018. I paste the code and I also attach the code and compilation results. Just to mention, the error is because of sentence "protrealvect(1)=5.d0". If I comment this one, the rest of the code works fine.
!C************************************************************
MODULE parent_module
IMPLICIT NONE
!> Private, public and public protected variables
INTEGER,PRIVATE::priv
INTEGER,PUBLIC::publ
INTEGER,PUBLIC,PROTECTED::prot
REAL(8),PUBLIC,PROTECTED::protreal
REAL(8),PUBLIC,PROTECTED,DIMENSION(1)::protrealvect
!> Submodule subroutine interface
INTERFACE
    MODULE SUBROUTINE modifVariables
    END SUBROUTINE modifVariables
END INTERFACE
END MODULE parent_module
SUBMODULE (parent_module) submod1
IMPLICIT NONE
CONTAINS
    priv=-1
    publ=2
    prot=-3
    protreal=-3.d0
END SUBMODULE submod1
FortranFan
It looks like a bug in the Intel Fortran compiler, note Intel now expects you to submit an incident on all their product-related issues at their Online Service Center (OSC) which you may want to do:
https://supporttickets.intel.com/?lang=en-US
FortranFan
Daniel_Dopico
Thank you FF. I already did that. Let's wait for their response and occasionally to have it corrected in the next release.
Daniel_Dopico
Finally, after "only" 5 months, this bug was corrected in the 2018 update 2. I had to guess it, because despite of all my efforts Intel didn't inform me about the correction. I am pretty sure that they are too busy to pay attention to the people paying for their licenses.
Daniel_Dopico
Well, to be honest, I have to point out that at least in this case, they told me in advance that apparently the bug was going to be fixed in the second next release, and they were right. I still miss more communication though.
