Internal Compiler Error with with Intel(R) Visual Fortran Compiler XE 13.1.1.171 [IA-32]
FortranFan
Steve,
The following code generates an internal compiler error (ICE).  I am able to work around by wrapping the offending code (i.e., per compiler complaint) in a separate function.  As you have explained in many posts, an ICE is always a compiler bug.  So will it be possible to open up a defect incident for this error?
Compiling with Intel(R) Visual Fortran Compiler XE 13.1.1.171 [IA-32]...
TestClass_ICE.f90
04010002_1529
..\TestClass\sor\TestClass_ICE.f90(79): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for ..\TestClass\sor\TestClass_ICE.f90 (code 1)
Build log written to  "file://..\TestClass\Debug\Win32\TestClassBuildLog.htm"
TestClass - 1 error(s), 0 warning(s)
[fortran]
   MODULE TestClassMod
      INTEGER, PARAMETER :: I4B = SELECTED_INT_KIND(9)
      INTEGER, PARAMETER :: DP  = SELECTED_REAL_KIND(15,307)
!.. Accessor class
      TYPE, ABSTRACT :: MyPropClassAbstract
      CONTAINS
         PRIVATE
         PROCEDURE(GetAbstract), PASS(This), DEFERRED :: Get
         PROCEDURE(SetAbstract), PASS(This), DEFERRED :: Set
         GENERIC, PUBLIC :: ASSIGNMENT(=) => Get, Set
      END TYPE MyPropClassAbstract
!.. Abstract Interface for Get, Set methods
      ABSTRACT INTERFACE
         ELEMENTAL SUBROUTINE GetAbstract(Value, This)
            IMPORT :: MyPropClassAbstract
            CLASS(*), INTENT(OUT)                    :: Value
            CLASS(MyPropClassAbstract), INTENT(IN)   :: This
         END SUBROUTINE
         ELEMENTAL SUBROUTINE SetAbstract(This, Value)
            CLASS(MyPropClassAbstract), INTENT(OUT) :: This
            CLASS(*), INTENT(IN)                    :: Value
         END SUBROUTINE
      END INTERFACE
      !.. Real Type
      TYPE, EXTENDS(MyPropClassAbstract), PUBLIC :: MyRealProp
         PRIVATE
         REAL(DP) :: MyValue
      CONTAINS
         PROCEDURE, PASS(This) :: Get => GetReal
         PROCEDURE, PASS(This) :: Set => SetReal
      END TYPE MyRealProp
!.. All entities private
      PRIVATE
!.. Test Class
      TYPE, PUBLIC :: TestClass
         PRIVATE
         !.. Internal class elements
         TYPE(MyRealProp)             :: MyT
      !.. Class methods
      CONTAINS
         !.. Private by default
         PRIVATE
         !.. Public methods
         PROCEDURE, PASS(This), PUBLIC :: set_T
      END TYPE TestClass
   CONTAINS
      !  Subroutine to set temperature
      SUBROUTINE set_T(This, UomLabel, Value)
         !.. Argument list
         CLASS(TestClass), INTENT(INOUT) :: This
         CHARACTER(LEN=*), INTENT(IN)    :: UomLabel
         REAL(DP), INTENT(IN)            :: Value
         This%MyT = Value
         SELECT CASE(UomLabel(1:1))
            CASE("K")
               This%MyT = Value
            CASE("C")
               This%MyT = Value + 273.15_dp   !.. Compiler doesn't seem to like this: bad code or compiler bug?
            CASE DEFAULT
            ! Insert Error handling here
         END SELECT
      END SUBROUTINE set_T
      !.. Get value of Real type
      ELEMENTAL SUBROUTINE GetReal(Value, This)
         !.. Argument list
         CLASS(MyRealProp), INTENT(IN) :: This
         !.. Process based on input type
         SELECT TYPE (Value)
            TYPE IS (REAL(DP))
               Value = This%MyValue
            CLASS DEFAULT
            !.. Insert error handling here
         END SELECT
      END SUBROUTINE GetReal
      !.. Set value of Real type
      ELEMENTAL SUBROUTINE SetReal(This, Value)
         !.. Argument list
         CLASS(MyRealProp), INTENT(OUT) :: This
         SELECT TYPE (Value)
            TYPE IS (REAL(DP))
               This%MyValue = Value
            CLASS DEFAULT
         END SELECT
      END SUBROUTINE SetReal
   END MODULE TestClassMod
 [/fortran]
Steven_L_Intel1
Thanks - I'll look at this and enter a defect report as needed. Feel free to use this forum to report such problems.
Steven_L_Intel1
Escalated as issue DPD200244716.
Steven_L_Intel1
Here's a workaround.  Declare a local variable of the same type as Value, say, Value_local. Then replace:
with:
Value_local = Value + 273.15_dp
This%MyT = Value_local
FortranFan
Thanks much Steve.  I assume the ICE will still be investigated as part of issue DPD200244716?  And hopefully fixed in a later release?
As I indicated in my original posting, a separate function is normally to be used for the math in a sub like this set_T in this project.  When the SELECT CASE construct was replaced with this function call, the ICE also disappeared.
Any explanation as to why the workarounds are able to get around the ICE?  Is it something to do with stack corruption?
Steven_L_Intel1
It's not stack corruption - just an inadequate code path in the compiler that isn't prepared to deal with some particular issue with this defined assignment and an arithmetic expression. Yes, the ICE is being investigated and will be fixed - but I thought you'd want to see a workaround if you wanted to continue developing until the fix is available.
Steven_L_Intel1
This problem has been fixed for a release later this year.
FortranFan
Excellent, thanks much for great support.
I can only hope now that the release that includes this fix comes out before my subscription ends or that my organization responds positively to my plea and funds the renewal of my subscription! :-)
