Internal compiler error / catastrophic error in IVF11 and XE
onkelhotte
New Contributor II
Hi Steve,
I tried to alter lassytouton's source he posted earlier (http://forum/280501/fortransocketclient.zipsoftware.intel.com/en-us/forums/showthread.php?t=71998&o=a&s=lr and https://forum/280501/fortransocketclient.zipgithub.com/lassytouton/LittleDemos/tree/master/Intel%20Visual%20FORTRAN%20TCP%20IP%20Sockets%20Based%20Client%20Server) . But then I get this:
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
I attached the solution. This happens on both IVF11.1 (which I use) and XE12.1 (I think he got the latest version). We use Visual Studio 2008 on a Windows7 x64 machine.
Markus
Wendy_Doerner__Intel
Valued Contributor I
Markus,
Steve is not here today, but I will take an look and try to reproduce the internal compiler error and see if we can find a workaround. Will post details back to this thread.
Wendy
Attaching or including files in a post
lassytouton
The following declaration in your code is incorrect. The MAP...END MAP for the CHARACTER buffer should be *INSIDE* the UNION.
    TYPE T_REAL4ARRAY
        SEQUENCE
            UNION
                MAP
                    REAL(kind=4) Temp2D(10,2)
                END MAP
            END UNION
            MAP
                CHARACTER buffer
            END MAP
    END TYPE T_REAL4ARRAY
It should read
    TYPE T_REAL4ARRAY
        SEQUENCE
            UNION
                MAP
                END MAP
                MAP
                    CHARACTER buffer
                END MAP
            END UNION
onkelhotte
New Contributor II
Youre right, that produces the error...
But the compiler should notice that, shouldnt it?
Yes an internal compiler error is always a compiler bug. Thanks for helping to narrow down the location in the code where the compiler is failing to give a proper error message. Sounds like you have a workaround for it.
I will get a test case into engineering so that we can fix it and give an error message. I will update this thread with the engineering tracking number and notification when it is fixed.
Wendy
Reproduced and narrowed down the test case the type definition mentionned above. The engineering tracking number is: DPD200178322. I will update this issue when a compiler which resolves it is available.
Wendy
With our 13.0 compiler we no longer give an internal error, but instead report the user error, see below. Wendy Doerner Intel Developer Support 1>------ Build started: Project: FortranSocketClient, Configuration: Debug Win32 ------ 1>Compiling with Intel(R) Visual Fortran Compiler XE 13.0.0.079 [IA-32]... 1>Reduced_Client.F90 1>C:\Users\wadoerne\Documents\Windows Forum\101873\FortranSocketClient\FortranSocketClient\FortranSocketClient\Reduced_Client.F90(36): error #6590: This statement is not permitted as a statement within a derived-type-def 1>C:\Users\wadoerne\Documents\Windows Forum\101873\FortranSocketClient\FortranSocketClient\FortranSocketClient\Reduced_Client.F90(70): error #6405: The same named entity from different modules and/or program units cannot be referenced. [SEND] 1>C:\Users\wadoerne\Documents\Windows Forum\101873\FortranSocketClient\FortranSocketClient\FortranSocketClient\Reduced_Client.F90(72): error #6405: The same named entity from different modules and/or program units cannot be referenced. [WSAGETLASTERROR] 1>compilation aborted for C:\Users\wadoerne\Documents\Windows Forum\101873\FortranSocketClient\FortranSocketClient\FortranSocketClient\Reduced_Client.F90 (code 1) 1> 1>Build log written to "file://C:\Users\wadoerne\Documents\Windows Forum\101873\FortranSocketClient\FortranSocketClient\FortranSocketClient\Debug\BuildLog.htm" 1>FortranSocketClient - 4 error(s), 0 warning(s) ========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
