Hi Steve,
I tried to alter lassytouton's source he posted earlier (http://forum/280501/fortransocketclient.zipsoftware.intel.com/en-us/forums/showthread.php?t=71998&o=a&s=lr and https://forum/280501/fortransocketclient.zipgithub.com/lassytouton/LittleDemos/tree/master/Intel%20Visual%20FORTRAN%20TCP%20IP%20Sockets%20Based%20Client%20Server) . But then I get this:
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
I attached the solution. This happens on both IVF11.1 (which I use) and XE12.1 (I think he got the latest version). We use Visual Studio 2008 on a Windows7 x64 machine.
Markus
Steve is not here today, but I will take an look and try to reproduce the internal compiler error and see if we can find a workaround. Will post details back to this thread.
Wendy
Attaching or including files in a post
The following declaration in your code is incorrect. The MAP...END MAP for the CHARACTER buffer should be *INSIDE* the UNION.
TYPE T_REAL4ARRAY
SEQUENCE
UNION
MAP
REAL(kind=4) Temp2D(10,2)
END MAP
END UNION
MAP
CHARACTER buffer
END MAP
END TYPE T_REAL4ARRAY
It should read
TYPE T_REAL4ARRAY
SEQUENCE
UNION
MAP
END MAP
MAP
CHARACTER buffer
END MAP
END UNION
But the compiler should notice that, shouldnt it?
I will get a test case into engineering so that we can fix it and give an error message. I will update this thread with the engineering tracking number and notification when it is fixed.
Wendy
Reproduced and narrowed down the test case the type definition mentionned above. The engineering tracking number is: DPD200178322. I will update this issue when a compiler which resolves it is available.
Wendy
