29281 Discussions
Internal compiler error when dealing with more than 4 classes
rogcar
Good afternoon
While testing use of more than 4 classes (parent, then 3 extends), I got an internal compiler error. No matter which compiling mode, the error remains. I attached some files that reproduces the internal error. Notice that ifyou remove one of the parent classes (i.e. child1, that could be easily removed from the example), the program works just fine.
Roger
Steven_L_Intel1
Perfect. I can reproduce the problem in 035 and 038 but not 046.
Steven_L_Intel1
I can't reproduce this in 11.1.046. Which version are you using? Please attach the buildlog.htm from the failed build, or the output of the command session if using that - be sure to show the ifort command used.
rogcar
Good afternoon, Steve
I'm using version 035. I didn't notice that until now. Just in case, I'm sending the buildlog as requested.
Thanks for replying
Roger,
Steven_L_Intel1
