I have run into an ICE with the program below. The compiler version I use is: Intel Fortran 12.0.3 under Linux. The program may not be correct, but the compiler does not give any message, except for the ICE.
Arjen
! primes_coarrays.f90 --
! Determine the first 1000 primes - using coarrays
program primes_coarrays
use, intrinsic :: iso_fortran_env, only: lock_type
implicit none
type(lock_type), codimension
integer, dimension(2), codimension
integer, dimension(1000), codimension
integer, codimension
logical, codimension
ready = .false.
new_results = .false.
new_task = .false.
number_primes = 0
range(2) = 0
! Create tasks in image 1 and handle them in all images
do while ( .not. ready )
if ( this_image() == 1 ) then
call add_task
endif
call get_task
enddo
write(*,'(10i5)') prime
contains
! Subroutine to post a new task (consisting of a
! range of integers in which to look for primes)
! Loop over the images to see which one wants a
! new task
subroutine add_task
integer :: i
do i = 1,num_images()
if ( .not. new_task ) then
range(1) = range(2) + 1
range(2) = range(2) + 100
range = range[1]
new_task = .true.
endif
enddo
end subroutine add_task
! Subroutine to get a task and search for
! primes inside the new range
subroutine get_task
integer, dimension(100) :: new_prime
integer :: lower
integer :: upper
logical :: isprime
logical :: got_task
integer :: np
integer :: i
integer :: j
integer :: residue
integer :: maxindex
got_task = .false.
np = 0
if ( new_task ) then
lower = range(1)
upper = range(2)
new_task = .false.
got_task = .true.
endif
if ( got_task ) then
write(*,*) 'Range: ',lower, upper, this_image()
do i = lower,upper
isprime = .true.
do j = 2,int(sqrt(real(i)))
residue = mod(i,j)
if ( residue == 0 ) then
isprime = .false.
exit
endif
enddo
if ( isprime ) then
np = np + 1
new_prime(np) = i
endif
enddo
endif
! Now put the results in image 1
lock( primes_lock )
maxindex = min( size(prime) - number_primes[1], np )
prime(number_primes+1:number_primes+maxindex)[1] = &
new_prime(1:maxindex)
number_primes[1] = number_primes[1] + maxindex
ready[1] = number_primes[1] >= size(prime)
unlock( primes_lock )
endif
end subroutine get_task
end program primes_coarrays
- « Previous
- 1
- 2
- Next »
no luck: the same result.
Arjen
What happens with
program HelloCoarrays
write(*,*) "Hello world from ", this_image()
end program HelloCoarrays
(compile for co-arrays)
Does the above hang on exit too?
Jim
no, that works okay. Hm, maybe I should reduce my program to the point
where it does correctly finish (at the expense of doing even less useful things)
I will let yyou know how I fare with that.
Arjen
The preliminary conclusion I think I can formulate is that it is the number of updates to the
prime array that is causing this. When I limited that (losing lots of information), it did finish
when all threads finished.
For the time being I can investigate an alternative solution - have thread 1 do all the updating.
Arjen
if(this_image() == 1) then
read(*,'(A)') line ! wait for user input
endif
end program yourProgramNameHere
add/reuse some character variable for line
then run the program but do not enter the text. i.e. let the program hang waiting for input.
In a seperate window run your favorite utility to see what is running on the system, in particular do you see one image running or multiple images running. The seperate images should have exited. If they have exited, then go back to the waiting image and press Return. See if this exits the program.
What I am asking you to check for is if there is a exit sequencing problem. If this seems to work then consider replacing the read with a call sleepqq(100) or some time interval long enough for the other images to exit.
Hopefully this will provide you with a work around until Intel can fix the problem.
If it doesn't work and the time difference is significant, the I suggest adding code at the end to get your process ID then issue a KILL process of that ID. A rather nasty way of working around the problem.
Jim Dempsey
what I see is that even though the threads reach the STOP statement, except for thread 1 that is
waiting for the input, all remain active.
As this is an example, not a critical thing, I will leave this version for the moment and see if my alternative
has more of a chance to work.
Arjen
- « Previous
- 1
- 2
- Next »
