Internal compiler errors with parametric objects (constructors, operators)
Trent_Hawkins
Regards Parallel Studio XE 2017 update 1
I tried to shorten the code snippet as much as possible:
#     ifndef matrix_algebra_F90
#     define matrix_algebra_F90
      module matrix_algebra
            implicit none
            integer,parameter::x_=8
            type::matrix(size)
               integer,len::size
               complex(kind=x_)::component(0:size,0:size)
            contains
               procedure,private::initialize_matrix
               procedure,private::initialize_matrix_factor
        end type  matrix
            interface matrix
               module procedure matrix_zeroes_constructor
               module procedure matrix_factor_constructor
        end interface matrix
            interface operator(*)
               module procedure matrix_matrix_matrix_contraction
        end interface operator(*)
      contains
            subroutine initialize_matrix(this,source)
                  implicit none
                  class(matrix(*))::this
                  complex(kind=x_),intent(in),optional::source(0:this%size,0:this%size)
                  if(present(source)) then
                     this%component=source
                  else
                     this%component=(0.0_x_,0.0_x_)
              end if!present(source)
        end subroutine initialize_matrix!this,source
            function matrix_zeroes_constructor(size) result(that)
                  implicit none
                  integer,intent(in)::size
                  type(matrix(size))::that
                  call that%initialize_matrix()
        end function matrix_zeroes_constructor!size
            subroutine initialize_matrix_factor(this,factor)
                  implicit none
                  complex(kind=x_),intent(in)::factor
                  integer::index
                  do index=0,this%size,+1
                     this%component(index,index)=factor
              end do!index=0,this%size,+1
        end subroutine initialize_matrix_factor!this,factor
            function matrix_factor_constructor(size,factor) result(that)
                  implicit none
                  complex(kind=x_)::factor
                  call that%initialize_matrix_factor(factor)
        end function matrix_factor_constructor!size,factor
            function matrix_matrix_matrix_contraction(matrix1,matrix2) result(matrix_)
                  implicit none
                  type(matrix(*)),intent(in)::matrix1
                  type(matrix(*)),intent(in)::matrix2
                  type(matrix(min(matrix1%size,matrix2%size)))::matrix_
                  matrix_%component=matmul(matrix1%component,matrix2%component)
        end function matrix_matrix_matrix_contraction!matrix1,matrix2
            function internal_errors(matrix0) result(matrix_)
                  implicit none
                  type(matrix(*)),intent(in)::matrix0
                  type(matrix(matrix0%size))::matrix_
                  matrix_=matrix(matrix0%size)                 ! OK
            !     matrix_=matrix(matrix0%size,(1.0_x_,0.0_x_)) ! **Internal compiler error: segmentation violation signal raised**
            !     matrix_=matrix_*matrix0                      ! **Internal compiler error: segmentation violation signal raised**
        end function internal_errors!matrix0
  end module matrix_algebra
#     endif
Any of the two commented lines alone in the last (test) function generates an internal compiler error. One uses a custom constructor, the other uses an overloaded operator. The use of the simple constructor runs OK. I think that the other constructor is well defined, as well as the matrix operation. In any case, it should generate a normal compiler error in any other case.
Xiaoping_D_Intel
Thanks for reporting the issue and I can reproduce it with 17.0 update 1. However, it no longer happens in the latest compiler binaries in development so the next release 17.0 update 2 will built it without error.
Xiaoping Duan
Intel Customer Support
Trent_Hawkins
Thank you! Is there perhaps a time-frame for releasing 17.0.2? I found a workaround and can go about my development, but it would be nice to pass the library to the team with constructor functions. (encapsulation)
Kevin_D_Intel
17.0 Update 2 target release is late next month (Feb. '17).
