29285 Discussions
Is it possible to use arrays on this way
cobek
Hello, I wonder if this can work?
*)dll subroutine:
subroutine Test(array)
!DEC$ ATTRIBUTES DLLEXPORT :: Test
use dflib
implicit none
character($MAXPATH), allocatable :: array(:)
integer n
n=4
allocate(array(n))
array(1)='A '
array(2)='B '
array(3)='C '
array(4)='D '
end subroutine
*)caller subroutine
interface
!DEC$ ATTRIBUTES DLLIMPORT :: Test
use dflib
implicit none
end subroutine
end interface
call Test(array)
...!do something with array
deallocate(array)
It is not standard Fortran 95, but having an ALLOCATABLE routine argument is part of a "Technical Report" for Fortran 2000 which is implemented by CVF 6.6B. This should work in that version of CVF. Make sure that the EXE is linked against the DLL form of the Fortran run-time library (the project wizard asks you if you'll be using a Fortran DLL when you create the project - say yes.) Otherwise the deallocate will fail.
Steve
