problem with OpenMP routine.
changhee
Hi.
My problem is that the openmp routine, 'omp_get_thread_num()' yields wrong result.
I'm using ifl 7.1 on windows server 2003.
I set the enviroment variable, OMP_NUM_THREADS to 8, and then ran the following openmp program.
program hello
integer num
write(6, *) "hello parallel world from threads ! "
!$omp parallel
num=omp_get_thread_num()
write(6, *) 'omp_num: ',num
!$omp end parallel
end
Starting the program above, I saw the following.
omp_num: -2147483648
The routine, 'omp_get_thread_num()' yield wrong result. In other words, the integer variable, 'num' must lie between 0 and 7.
Any ideas what the problem can be?
You didn't INCLUDE the OpenMP definitions file, so the routine is implicitly REAL.
Steve
changhee
Thanks steve.
You're right.
I've forgot typing 'use omp_lib' .
Changhee
