I see there are functions to multiply and transpose a matrix, is there one to invert a matrix?
David
David
No, there's no standard function to invert a matrix.
First, note that LU decomposition + solution of linear system is far preferred method to matrix inversion. Matrix inversion is seldom really needed (only if you'll need the inverted matrix for many times afterwards).
I use linpack routines from netlib for that. See ssifa, sgefa and ssisl; make sure to download the underlying BLAS routines & dependencies as well (there's an appropriate option during the download). (Double precision equivalents have prefix "d" instead of "s").
Jugoslav
Jugoslav
I believe that the IMSL routines that come with the professional version of CVF include one to invert a matrix. I can't verify that right now because my system with CVF pro installed is down.
Mike
Mike
Yes, IMSL has several, depending on the type of matrix you want to invert (real,complex,positive definite...) and with and without iterative refinement.
The docs say they are based on/ derived from linpack and laback.
