List directed I/O error Help.
pecan204
I am getting a list direct I/O syntax error. Everything compiled and created an execuatable.
Does eveything look legal in the file. It is usung an adjustable array in the read.
Thanks, Here is the file.
 program read_data
 USE ReadConfigFile
 Implicit Double Precision ( A-H, O-Z), Integer (I-N)
 Character*80 filepath(3),file1, file2, file3
 Double precision, Allocatable :: xread1(:),xread2(:),xread3(:)
 Dimension nvars_in_file(3)
 call gtconfig(nvars_in_file, filepath)
  lin2 = 2
  lin3 = 3
  lin4 = 4
! default sequential, formatted
 open(unit=lin2,file=trim(filepath(1)),status='old',mode='read',share='denynone')
 open(unit=lin3,file=filepath(2),status='old',FORM='formatted')
 open(unit=lin4,file=filepath(3),status='old',FORM='formatted')
  nv1 = nvars_in_file(1)
  nv2 = nvars_in_file(2)
  nv3 = nvars_in_file(3)
 ALLOCATE(xread1(nv1),xread2(nv2),xread3(nv3))
 Read(lin2,*) (xread1(i), i=1,nv1)
 Read(lin3,*) (xread2(i), i=1,nv2)
 Read(lin4,*) (xread3(i), i=1,nv3)
end program Read_data
Intel_C_Intel
Don't you need TRIM fr the second and the third OPEN too? Couldn't the PATH be longer than 80 characters?
Sabalan.
The TRIM isn't necessary in this case. Trailing blanks in filespecs are ignored. If it was a problem with the OPEN, the error from the READ would be different.
Without seeing the data file, it's difficult to analyze the problem. You should be able to figure out which line (or lines) are being read to help narrow it down.
Steve
pecan204
Thanks for the replies.
After reading them I was able to focus more on the file and found that the first field had a time stamp. It bombed on the read of the time.
Such as 12:01:01
The other fields had floating point or integers.
Any suggestions on handling the time? I do need the parameter for later processing.
Read it as a string with an (A) format.
Steve
