LINK ERROR: UNRESOLVED EXTERNAL
khhong7intel
Principiante
1.203 Vistas
Hello Steve,
I am using Visual Fortran V.9 with Visual Studio 2005.
Got link error for C call to a Fortran routine
and no link error for Fortran call to a C routine even though there is no C routine called.
It seems that there were no communications between C-side and Fortran library side.
The two files are at the end of this message.
Actually, I made the simple example using Compaq Fortran and Visual C++ v.6 and converted it into two parts (: proj and proj_lib) under one solution using Visual Fortran V.9 with Visual Studio 2005.
C part into proj and Fortran part into proj_lib as a static library.
I got link error:
error LNK2019: unresolved external symbol _mainprog referenced in function _WinMain@16
It worked before the break up into two parts with Compaq and VC++ v.6.
-K. Hong
Fortran-file f1.f
subroutine mainprog( )
!DEC$ ATTRIBUTES C :: mainprog&nbs p;
interface
subroutine f2c(n1)
!DEC$ ATTRIBUTES C :: f2c
integer n1
end subroutine
end interface
n=10
call f2c(n)
return
end
C-file c1.c
#include "stdafx.h"
extern void mainprog(void);
int APIENTRY WinMain(HINSTANCE hInstance,
HINSTANCE hPrevInstance,
LPSTR lpCmdLine,
int nCmdShow)
// TODO: Place code here.
mainprog();
return 0;
0 kudos
8 Respuestas
Steven_L_Intel1
Empleados
1.203 Vistas
Two things to check. 1) Make sure that you have installed VS2005 SP1. 2) Right click on the C++ project, select Dependencies. Ensure that the Fortran project is a dependent of the C++ project.
khhong7intel
Principiante
1.203 Vistas
Steve,
I amdpwnloadingthe SP1.
In the mean time, I followed your advice. However,
I could not make the Fortran project is a dependent of the C++ project.
I got "circular dependency" warning.
For some reason, I could do the other way only
even though I made C side main and Fortran side static.
Any idea?
-K. Hong
Steven_L_Intel1
Empleados
1.203 Vistas
I don't know what you've done to create the circular dependence - I didn't think one could manage that using the menus. Make sure that the C++ project is the "startup project".
khhong7intel
Principiante
1.203 Vistas
Hello Steve,
Here are the steps taken so far:
1. Double click the existing workspace of VC++ v.6.
2. Yes to allto "Convert and open this project?"
3. I got one project under one solution.
4. In the source file, I had f1.f and c1.c
5. Right clicked on the project and selected Extract Compaq Fortran Project Items
6. I chose The Visual C++ project at the question Select the project that will be the main project. Then OK.
7. Now I got a new Fortran static library project proj_lib.
8. Set the dependencies by right mouse click on Fortran static project or C-proj.
9. I get an error regardless of the dependency.
(a) Fortran depends on C : can not file ifconsol.lib
(b) C depends on Fortran: unresolved error for a Fortran function call from C.
-K. Hong
Steven_L_Intel1
Empleados
1.203 Vistas
Please create a ZIP of your project(s) and attach it to a report to Intel Premier Support. We'll take a look.
Intel_C_Intel
Empleados
1.203 Vistas
I've just sent the report to Premium Support with my project files uploaded.
-K. Hong.
khhong7intel
Principiante
1.203 Vistas
Hello Steve,
Are you working on the problem?
Please let me know?
-K.Hong
Steven_L_Intel1
Empleados
1.203 Vistas
Yes, and I responded to you through Premier Support. Check to make sure that the email notifications don't get treated as spam in your mailbox.
The sample you sent me did not show a problem, but it was different from what you described here.
Responder
