I am familiar with the Listbox and have used it successfully many times. Now, I am attempting to use the LISTVIEW control in a dialog box. I have successfully loaded data into the control, but now I want the application to call a subroutine when an a row is clicked in the LISTVIEW control. I have used the "dlgsetsub" funtion to define which callback subroutine to call, but nothing happens when a row in the LISTVIEW control is clicked. Should this work or should I be doing something different. Any help that you can provide would be greatly appreciated.
Unfortunately, no, ListView is not supported by DFLOGM, so you'll have to cope with pure API handling. This is somewhat less elegant (but more powerful) than Dlg* family of routines.
Here's a code snippet from an actual application which handles the dialog whose screenshot is in the attachment.
(There are two similar ListViews, which are shown/hidden depending on tab control state; I snipped the code which handles the second because it's more or less identical).
It is a bit more complicated since it's from an actual app, but hope it would be helpful.
HTH
Jugoslav
!========================================================= INTEGER(4) FUNCTION ScadaIDDlgProc(hWnd,Msg,wParam,lParam) !DEC$ATTRIBUTES STDCALL:: ScadaIDDlgProc USE DFWIN USE LANGDEP USE OPCCLIENT USE COMCTL USE STRINGS USE REGISTRY USE UKS USE me_com1 IMPLICIT NONE INCLUDE "Resource.fd" INTEGER, INTENT(IN):: hWnd, Msg, wParam, lParam INTEGER:: i, iSt, hIcon, iIcon INTEGER, SAVE:: hImageList = 0, hList1, hList2 CHARACTER(100):: sID TYPE(T_LV_ITEM):: Item TYPE(T_TC_ITEM):: TabItem TYPE(T_LV_COLUMN):: Column TYPE(T_NM_LISTVIEW):: LV; POINTER(pLV,LV) TYPE(T_NMHDR):: Hdr; POINTER(pHdr,Hdr) INTEGER, PARAMETER:: sColumn(0:4)=(/S_SCADAID, S_DMSID, S_STATUS, S_QUALITY, S_LOCATION/) INTEGER, PARAMETER:: sMerColumn(0:5)=(/S_SCADAID, S_DMSID, S_VALUE, S_TYPE, & S_QUALITY, S_LOCATION/) INTEGER, PARAMETER:: sQuality(1:3)=(/S_GOOD, S_UNCERTAIN, S_BAD/) INTEGER, PARAMETER:: iColWidth(0:4)=(/60, 60, 40, 40, 312/) INTEGER, PARAMETER:: iMerColWidth(0:5)=(/60, 60, 60, 40, 40, 252/) INTEGER, PARAMETER:: idIcon(0:2)=(/IDI_ICON_GOOD, IDI_ICON_UNCERTAIN, IDI_ICON_BAD/) !This is the function for sorting elements by columns INTERFACE INTEGER FUNCTION ListSortFunc(i1,i2,i3) !DEC$ATTRIBUTES STDCALL:: ListSortFunc INTEGER:: i1,i2,i3 END FUNCTION ListSortFunc END INTERFACE SELECT CASE(MSG) CASE (WM_INITDIALOG) hList1 = GetDlgItem(hWnd, IDC_LIST1) hList2 = GetDlgItem(hWnd, IDC_LIST2) TabItem%mask = TCIF_TEXT TabItem%pszText = LOC(sID) !.C. is a character function which loads a string !from a dll string table. Use normal strings instead. sID = .C.S_SWITCHGEAR iSt = SendMessage(GetDlgItem(hWnd, IDC_TAB1), TCM_INSERTITEM, 0, LOC(TabItem)) sID = .C.S_MEASUREMENTS iSt = SendMessage(GetDlgItem(hWnd, IDC_TAB1), TCM_INSERTITEM, 1, LOC(TabItem)) iSt = ShowWindow(hList1, SW_SHOW) iSt = ShowWindow(hList2, SW_HIDE) iSt = ShowWindow(GetDlgItem(hWnd,IDC_STATIC1), SW_SHOW) iSt = ShowWindow(GetDlgItem(hWnd,IDC_STATIC2), SW_HIDE) iSt = SendMessage(GetDlgItem(hWnd, IDOK), BM_SETIMAGE, IMAGE_ICON, hicoOK) !Setting up the header control DO i=0,4 Column%mask = LVCF_FMT + LVCF_ORDER + LVCF_SUBITEM + LVCF_TEXT + LVCF_WIDTH Column%fmt = LVCFMT_LEFT Column%cx = iColWidth(i) sID = .C.sColumn(i) Column%pszText = LOC(sID) Column%cchTextMax = 0 Column%iSubItem = i Column%iImage = 0 Column%iOrder = i iSt = SendMessage(hList1, LVM_INSERTCOLUMN, i, LOC(Column)) END DO DO i=0,5 sID = .C.sMerColumn(i) Column%cx = iMerColWidth(i) Column%iSubItem = i Column%iOrder = i iSt = SendMessage(hList2, LVM_INSERTCOLUMN, i, LOC(Column)) END DO DO i=1,iBrKom IF (iRConPr(i).NE.0) THEN iIcon = 0 Item%mask = LVIF_TEXT + LVIF_IMAGE + LVIF_PARAM Item%iItem = 0 Item%state = 0 Item%statemask = 0 Item%cchTextMax = 0 Item%iImage = -1 !lParam is optional; here it is used !to associate data with each row, in !order to enable sorting Item%lParam = i Item%iSubItem = 0 CALL GetScadaID(i, 1, sID) IF (LEN_TRIM(sID).LE.1) iIcon = 1 sID = TRIM(sID)//CHAR(0) Item%pszText = LOC(sID) iSt = SendMessage(hList1, LVM_INSERTITEM, 0, LOC(Item)) Item%mask = LVIF_TEXT Item%iSubItem = 1 sID = STRING(iSifPr(i),9) sID = TRIM(sID)//CHAR(0) iSt = SendMessage(hList1, LVM_SETITEM, 0, LOC(Item)) Item%iSubItem = 2 sID = STRING(iStPr(i),1) sID = TRIM(sID)//CHAR(0) iSt = SendMessage(hList1, LVM_SETITEM, 0, LOC(Item)) Item%iSubItem = 3 sID = .C.sQuality(iRConPr(i)) Item%iImage = iRConPr(i)-1 iSt = SendMessage(hList1, LVM_SETITEM, 0, LOC(Item)) Item%iSubItem = 4 CALL GetSwitchName(iSifPr(i), sID, .TRUE., iSt) IF (LEN_TRIM(sID).LE.1) iIcon = 2 sID = TRIM(sID)//CHAR(0) iSt = SendMessage(hList1, LVM_SETITEM, 0, LOC(Item)) IF (iIcon.NE.0) THEN Item%mask = LVIF_IMAGE Item%iSubItem = 0 Item%iImage = iIcon iSt = SendMessage(hList1, LVM_SETITEM, 0, LOC(Item)) END IF END IF END DO !!Adding icons to the list hImageList = ImageList_Create(16, 16, ILC_COLOR+ILC_MASK, 6, 2) DO i=0,2 hIcon = LoadImageA(hInst, idIcon(i), IMAGE_ICON, 16, 16, LR_DEFAULTCOLOR ) iSt = ImageList_ReplaceIcon(hImageList, -1, hIcon) END DO iSt = SendMessage(hList1, LVM_SETIMAGELIST, LVSIL_SMALL, hImageList) iSt = SendMessage(hList2, LVM_SETIMAGELIST, LVSIL_SMALL, hImageList) ScadaIDDlgProc = .FALSE. CASE (WM_COMMAND) IF (LOWORD(wParam).EQ.IDOK) THEN iSt = EndDialog(hWnd, IDOK) END IF ScadaIDDlgProc = .TRUE. CASE (WM_NOTIFY) pHdr = lParam IF (wParam.EQ.IDC_LIST1) THEN IF (hdr%code.EQ.LVN_COLUMNCLICK) THEN pLV = lParam iSt = SendMessage(hList1, LVM_SORTITEMS, LV%iSubItem+1, LOC(ListSortFunc)) END IF ELSE IF (wParam.EQ.IDC_LIST2) THEN IF (hdr%code.EQ.LVN_COLUMNCLICK) THEN pLV = lParam iSt = SendMessage(hList2, LVM_SORTITEMS, -LV%iSubItem-1, LOC(ListSortFunc)) END IF ELSE IF (wParam.EQ.IDC_TAB1) THEN IF (hdr%code.EQ.TCN_SELCHANGE) THEN iSt = SendMessage(GetDlgItem(hWnd, IDC_TAB1), TCM_GETCURSEL, 0, 0) IF (iSt.EQ.0) THEN iSt = ShowWindow(hList1, SW_SHOW) iSt = ShowWi ndow(hList2, SW_HIDE) iSt = ShowWindow(GetDlgItem(hWnd,IDC_STATIC1), SW_SHOW) iSt = ShowWindow(GetDlgItem(hWnd,IDC_STATIC2), SW_HIDE) ELSE iSt = ShowWindow(hList1, SW_HIDE) iSt = ShowWindow(hList2, SW_SHOW) iSt = ShowWindow(GetDlgItem(hWnd,IDC_STATIC1), SW_HIDE) iSt = ShowWindow(GetDlgItem(hWnd,IDC_STATIC2), SW_SHOW) END IF END IF END IF CASE DEFAULT ScadaIDDlgProc = .FALSE. END SELECT END FUNCTION ScadaIDDlgProc !================================ INTEGER FUNCTION ListSortFunc(i1,i2,iColumn) !DEC$ATTRIBUTES STDCALL:: ListSortFunc USE me_com1 USE UKS IMPLICIT NONE INTEGER, INTENT(IN):: i1,i2,iColumn CHARACTER(100):: sID1, sID2 INTEGER:: iSt IF (iColumn.GT.0) THEN !Prekidaci SELECT CASE (iColumn) CASE(1) CALL GetScadaID(i1, 1, sID1) CALL GetScadaID(i2, 1, sID2) IF (sID1.EQ.sID2) THEN ListSortFunc = 0 ELSE IF (sID1.GT.sID2) THEN ListSortFunc = 1 ELSE ListSortFunc = -1 END IF CASE(2) ListSortFunc = iSifPr(i1)-iSifPr(i2) !Snipped the rest
HTH
Jugoslav
Thanks for the input. I was hoping there may be an easy way to use a LISTVIEW control without getting to deep into API handling. Any thoughts on how to handle a LISTVIEW while still using DFLOGM would be appreciated.
Joe
Joe
Well, there are two ways, none of them particularly attractive:
- The "pure" way is to use ActiveX wrapper for ListView control (it is located in comctl32.ocx). All that ActiveX stuff is Greek to me so you'll have to rely on samples, MSDN documentation and pelhaps help from other Forum participants.
- The other way is to tweak DFLOGM.f90 (my favourite sport) to roll your own ListView (or, perhaps, general "unknown control") support, i.e. develop the structure, handle WM_COMMAND and WM_NOTIFY etc.
Jugoslav
Jugoslav
Hi there,
I created a ListView Control and I am able toinsert new columns, items etc. The difference is the implemantation of the code. You insert new data by messages, I set them when I create the dialog within the MainDialog Callback Routine.
Now I tried to implement two features: Sorting the columns and edit the label. But where do I "intercept" the WM_NOTIFY Message? Do I have to rewrite the code?
Code:
l = DlgInit(IDD_DIALOG_Main, dlgMain) l = DlgSetSub(dlgMain, IDD_DIALOG_Main, MainInit) ... l = DlgModeless(dlgMain) do while( GetMessage (mesg, NULL, 0, 0) ) if (DlgIsDlgMessage(mesg) .EQV. .FALSE. ) then lret = TranslateMessage( mesg ) ret = DispatchMessage( mesg ) end if end do ... ! ********************************************************************* SUBROUTINE MainInit( dlg, id, callbacktype ) ! ********************************************************************* use... ListHwnd = GetDlgItem(dlg.hwnd,IDC_LIST_Chemie) l = SendMessage(ListHwnd,LVM_SETEXTENDEDLISTVIEWSTYLE,0,LVS_EX_FULLROWSELECT) LVColumn.mask = LVCF_FMT+LVCF_ORDER+LVCF_SUBITEM+LVCF_TEXT+LVCF_WIDTH LVColumn.cchTextMax = 0 LVColumn.iImage = 0 LVColumn.fmt = LVCFMT_RIGHT ... l = SendMessage(ListHwnd, LVM_INSERTCOLUMN, 0, LOC(LVColumn)) LVColumn.fmt=LVCFMT_LEFT ... l = SendMessage(ListHwnd, LVM_INSERTCOLUMN, 1, LOC(LVColumn)) ... end subroutin
Basically, you can't :-(. Either you must tweak DFLOGM.f90 code or insert an ugly
In the meantime, I developed ListView support in <XFT library with kind help of Mike Gaitens -- check out the LVTest sample.
I hope the code and documentation are clear enough.
Jugoslav
if (Msg%message.EQ.WM_NOTIFY .AND. Msg%hWnd.EQ.Dlg%hWnd .AND. &
(the NMHDR%idFrom is listview control)) then
!do something
else
TranslateMessage
DispatchMessage
end if
Jugoslav
Topic Options
