29487 Discussions
LLVM (ifx): a higher-order function causes segmentation fault on EndeavourOS
EKawashima
Consider the following Fortran file:
program main
  implicit none
  integer :: n
  n = 0
  call f(1)             ! OK
  print *, n
  call higher_order(f)  ! segmentation fault occurs if ifx compiles with -O0
  print *, n
contains
  subroutine f(arg)
    implicit none
    integer, intent(in) :: arg
    n = n + arg
  end subroutine
  subroutine higher_order(func)
    implicit none
    interface
      subroutine func(arg)
      end subroutine
    end interface
    call func(1)
  end subroutine
end program
On EndeavourOS (GCC and libc are 13.1.1 and 2.37, respectively), if the file is compiled by ifx (Version 2023.1.0 Build 20230320) with -O0, segmentation fault occurs:
           1
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image              PC                Routine            Line        Source
libc.so.6          000014FAE4C4FAB0  Unknown               Unknown  Unknown
Unknown            00007FFDC84985D8  Unknown               Unknown  Unknown
The program works successfully if
  • compiled by ifx with -O1 or higher
  • compiled by ifort (Version 2021.9.0 Build 20230302_000000) with -O0 or higher
No warnings are issued with -std18 -warn all.
On Rocky Linux 8.7, where GCC and libc are respectively 8.5.0 and 2.28, segmentation fault does not occur even if compiled with -O0.
Labels (2)
jimdempseyatthecove
A segmentation fault is definitely an error in the compiler generated code.
Note, contained procedures have implicit interfaces be it from within the parent procedure or other contained procedures.
Do you get the error without your (unnecessary) interface?
Jim Dempsey
Steve_Lionel
As another data point, the program runs fine with ifx -Od (equivalent to -O0) on Windows. That the segfault occurs in libc is peculiar.
Ron_Green
I'm trying to find a system with glibc 2.37.  Newest I have is glibc 2.36 which runs just fine.  Ubu 22.10.  I can try to upgrade to Ubu 23.04 perhaps.
But I have to tell you the company position:  You are using an unsupported OS and version.  Your glibc has not been validated.
could you compile adding both
-g -traceback
and re-run so we get a traceback to the source line that is seg faulting?
EKawashima
Thank you for your quick replies.
-g -traceback
The following is the output:
           1
libc.so.6          00007F823FB2FAB0  Unknown               Unknown  Unknown
Unknown            00007FFC961C4EB8  Unknown               Unknown  Unknown
gdb backtrace:
(gdb) bt
#0  0x00007fffffff85a8 in ?? ()
#1  0x0000000000405312 in main::higher_order (func=0x4052c0bb49) at a.f90:23
#2  0x0000000000405253 in main () at a.f90:7
#3  0x000000000040517d in main ()
Ron_Green
System Requirements shows the versions and distros we officially support.  I do not have a server I can update to that version of glibc and gcc.  And I'm afraid it would only tell us what we already know: the compiler just does not support this bleeding edge distro/version. I will try to find a server, and also see when gcc 13 and your glibc are expected to be supported.
EKawashima
Thank you for your replies and kind attention.
It is inlining that the program runs successfully if compiled by ifx and -O1:
FCcompile optionsresult
ifx-O0segmentation fault
ifx-O1 -fno-inlinesegmentation fault
ifx-O1OK
ifort-O0OK
EKawashima
ifort and gfortran issue the following warning in linkage on EndeavourOS:
ld: warning: a.o: requires executable stack (because the .note.GNU-stack section is executable)
Hence I tried the following linkers
  • bfd (the default): 2.40.0
  • gold: 1.16
  • lld: 15.0.7
and options (https://www.redhat.com/en/blog/linkers-warnings-about-executable-stacks-and-segments
FClinkercompile optionlink optionresult
ifxbfd-O0 segmentation fault
ifxgold-O0 success
ifxlld-O0 segmentation fault
ifxbfd-O0-Wl,-z,execstacksuccess
ifxgold-O0-Wl,-z,execstacksuccess
ifxlld-O0-Wl,-z,execstacksuccess
ifxbfd-O0-Wl,-z,noexecstacksegmentation fault
ifxgold-O0-Wl,-z,noexecstacksegmentation fault
ifxlld-O0-Wl,-z,noexecstacksegmentation fault
ifxbfd-O1 success
ifxgold-O1 success
ifxlld-O1 success
ifxbfd-O1-Wl,-z,execstacksuccess
ifxgold-O1-Wl,-z,execstacksuccess
ifxlld-O1-Wl,-z,execstacksuccess
ifxbfd-O1-Wl,-z,noexecstacksuccess
ifxgold-O1-Wl,-z,noexecstacksuccess
ifxlld-O1-Wl,-z,noexecstacksuccess
ifortbfd-O0 success
ifortgold-O0 success
ifortlld-O0 segmentation fault
ifortbfd-O0-Wl,-z,execstacksuccess
ifortgold-O0-Wl,-z,execstacksuccess
ifortlld-O0-Wl,-z,execstacksuccess
ifortbfd-O0-Wl,-z,noexecstacksegmentation fault
ifortgold-O0-Wl,-z,noexecstacksegmentation fault
ifortlld-O0-Wl,-z,noexecstacksegmentation fault
On Rocky Linux 8.7, where ld.bfd and ld.gold are respectively 2.30-117.el8 and 1.15, the behaviours are independent on the linker:
FCcompile optionlink optionresult
ifx-O0 success
ifx-O0-Wl,-z,execstacksuccess
ifx-O0-Wl,-z,noexecstacksegmentation fault
ifx-O1 success
ifx-O1-Wl,-z,execstacksuccess
ifx-O1-Wl,-z,noexecstacksuccess
ifort-O0 success
ifort-O0-Wl,-z,execstacksuccess
ifort-O0-Wl,-z,noexecstacksegmentation fault
On both OS's, gfortran 13.1.1/8.5.0 behaves the same as ifort.
So perhaps there is something wrong with linkage
Many thanks.
jimdempseyatthecove
The above outputs (0x00007fffffff85a8 in ?? ()) looks as if the code being executed has been created at runtime and is placed on the stack .AND. the particular linker/option/lack-of-option is annotating that the stack segment is to be set to read/write but inhibit execute.
It may be of interest to produce two load maps using a linker that produces both the success and segmentation fault. This might provide additional input.
I suspect that there is something in the selected CRTL that is generating code at runtime, that is placed on the stack or on the heap.
Note, historically, some viruses would do this, and to defeat this, the CPU selector registers added flags for Read, Write, and Execute.
Note-2, the above is not to be a statement to say your program (or CRTL) has a virus. Rather, something unusual is happening that requires the stack be flagged for permission to execute.
Jim Dempsey
