program IOSpeed
use system_time_mod
use ifport
implicit none
integer :: l, n, n1, n2, n3, iostat, sysstat
real :: fs
type(timer) :: tr, tw
real, dimension(:,:,:), allocatable :: data
call system_time_init()
! Loop over increasing file size,
sysstat = system("touch /tmp/test")
do l=1,10
n = 512000*(2**l)
n1 = 512
n2 = 1000
n3 = n/n1/n2
allocate( data(n1,n2,n3) )
sysstat = system("rm /tmp/test")
open(1,file='/tmp/test',form='BINARY',status='NEW',iostat=iostat)
call start_timer(tw)
write(1) data
call stop_timer(tw)
rewind(1)
call start_timer(tr)
read(1) data
call stop_timer(tr)
fs = (1.0*n*4)/1024000
write(0,*) fs,fs/tw%telapsed,fs/tr%telapsed
close(1)
deallocate(data)
end do
call exit(0)
end program IOSpeed
A few caveats about the code:
1) I'm using the Intel fortran compiler, hence the use ifport to enable system calls
2) I'm using a timing module of my own creation (just a front-end for system_clock())
3) The BINAR
Y file type is not necessarily a fortran standard (to my knowledge)
I'm using the following ifort flags:
-assume bscc -assume byterecl -fpp -mtune=pentium4 -O3 -static-intel -vms -w -WB -threads
If you run the code, for each file size, it prints the file size, and the I/O speed for the read and write in MB/sec.
My machine:
1) Intel quad core 64-bit, 4GB shared memory
2) Fedora Core 7
3) /tmp is ext3 (I converted another disk to ext2 (no journaling) and see the same behavior)
Here is a GNUPLOT figure of the performance, for three separate runs.
http://www.voxproperty.com/images/2008_01_09_f90_io_speed_vs_filesize.png
You will notice a fairly predictable performance pattern for each file size. The sampling along the x-axis is non-uniform--data occurs at powers of 2: 2MB, 4MB, ... 2048 MB. Write performance declines precipitously at 256 MB, whereas read performance declines
precipitously at 1024 MB.
I won't be surprised if this is a system issue, but just in case it's something that can be improved with compiler optimization or programming habits, I posted here.
Thank you for your time...
4Gb machine (replotted with lines and points):
http://www.voxproperty.com/images/2008_01_09_f90_io_speed_vs_filesize_brown01.png
2Gb machine:
http://www.voxproperty.com/images/2008_01_09_f90_io_speed_vs_filesize_brown02.png
Hmm....
I have a RAID5-enabled disk, and I notice that base I/O rate is about double that to regular local disk. But I do see the same dropoff.
Here is a thread on comp.lang.fortran where a poster has repeated the behavior; thus it's probably not an ifort issue, per se.
I presume you have a utility called blockdev on your Linux system.
Try blockdev --getra /dev/hda to get the current number of readahead sectors. It is probably set to 256. Increase it with blockdev --setra 16384 /dev/hda
(replace the device name)
Readahead will of course only improve read operations, although there are also plenty of read operations involved when you write a file (updates of the file system, allocation tables). Play with the number a bit. Try 8192 and 32768. But do not make the number too large. Optimize the number for each disk based on the application. File transfers from a disk with lots of large data benefit from a larger number, while the disk with the operating system works better with a smaller number.
Try to optimize the ratio of the buffer size in your Fortran READ and the readahead buffer size (maybe ratio 1:2).
If you use a RAID system, then check the number of blocks per group (see documentation of mkfs.ext3).
Try alternative journaling file systems (JFS, ReiserFS, maybe xfs).
For a real-world application you would probably want to do an asynchronous I/O.
Looking forward to see some new plots.
Morgan,
I suggest you experiment using RECL=nnn on the OPEN(s) then writing/reading stripes of the array as opposed to using the default RECL and writing the whole array in "one" operation. Often the default values give less than stellar performance.
Jim Dempsey
Morgan,
A second hint. Extending a file with each sequential write often takes much longer than computing the file size, writing a "junk" last record, rewinding, then writing into preallocated disk space.
Jim Dempsey
(On VMS I also find EXTENDSIZE quite useful.)
