License file required
Pelletier__Alain
I just got a new computer with Windows 10 and I wanted to reinstall Intel Parallel Studio Composer Edition 2016 for Fortran Windows (with Visual Studio 2013- 2013 Shell Integrated). I therefore need a license file for the reinstallation.
Thank you
Steve_Lionel
Log in to https://registrationcenter.intel.com and you can find all your registered licenses. You will just need the serial number.
Steve_Lionel
Yes, that's true. When you supply a valid serial number to the install, it creates a .lic file in the appropriate folder.
If you need more help with licenses, you'll need to open a support ticket with Intel Support, not this forum.
Nania__Leonardo
I have a problem similar to Alain. I had to replace my hard disk and I need to install again Intel® Visual Fortran Studio XE for Windows in the same laptop now with Windows 10. I have an academic license.
I know that that software has been discontinued and therefore I have not a way to reinstall the software. The only solution Intel gave to me is to renew the license to Intel Parallel, but I cannot afford it right now. Is there some repository to found the install files? Is there any way using a license file I could recover from my old disk in order to reinstall the software? Is there any other solution?
Thank you very much for your help.
Leonardo
