License renewal error
smarras_bscgmail_com
Hi everyone,
Apologies if this thread is repeated, but I did not find a similar problem yet.
I downloaded a 1-month license to use the11.0/059 version of an evaluation fortran compiler for Mac OSX.
Although I went through the same steps before without any problem (download the license file and put it in a proper PATH searchable by ifort), this time, when I try to compile my code, I obtain the following error:
Error: A license for FCompM could not be obtained.
Your license has expired.
License file(s) used were (in this order):
1. Trusted Storage
2. /opt/intel/Compiler/11.0/059/licenses
3. /opt/intel/licenses/EVAL_xxxxxx.lic
4. /Users/mymac/intel/licenses
5. /Users/Shared/Library/Application Support/Intel/Licenses/EVAL_xxxxxxxx.lic
6. /Users/Shared/Library/Application Support/Intel/Licenses/license_xxxxxxxxxx.lic
7. /opt/intel/Compiler/11.0/059/bin/intel64/EVAL_xxxxxxxxx.lic
Please visit http://www.intel.com/software/products to obtain license renewal information.
I hope anyone is able to help with the issue.
Best,
S.
Kevin_D_Intel
First, please do not post any additional serial numbers into the forum.
The various eval subscriptions evident from the error received have all expired as per their 30-day term, hence, the compiler is unable to find a valid license among those it found.
Your post is not clear about what the issue/concern is, so could you elaborate about what the issue/concern is?
If the issue involves a new evaluation serial number, please do not post that here, just let us know and we'll perhaps redirect this to our Start-up Support team if we can't help you here.
Hi, thanks fro replying. Sorry about posting the serial numbers, but those are expired so that I didn't think it could do any harm.
However, the issue is due to the fact that I obtained that same error although I indeed put a new license file in the searching path.
Who should I write to about this issue?
Best
Kevin_D_Intel
Please send email to: kevin.d.davis@intel.comwith a copy of the new license attached. We'll work this offline.
