I have been having trouble linking Abaqus with the compiler. I used the following tutorial to link the softwares:
https://www.youtube.com/watch?v=ImWUFZAKlr4.
I'm using Abaqus 6.14-5 with Intel Parallel XE 2013 with VS 2010. The UMAT code is:
SUBROUTINE UMAT(STRESS,STATEV,DDSDDE,SSE,SPD,SCD,
1 RPL,DDSDDT,DRPLDE,DRPLDT,
2 STRAN,DSTRAN,TIME,DTIME,TEMP,DTEMP,PREDEF,DPRED,CMNAME,
3 NDI,NSHR,NTENS,NSTATV,PROPS,NPROPS,COORDS,DROT,PNEWDT,
4 CELENT,DFGRD0,DFGRD1,NOEL,NPT,LAYER,KSPT,KSTEP,KINC)
C
INCLUDE 'ABA_PARAM.INC'
C
CHARACTER*80 CMNAME
DIMENSION STRESS(NTENS),STATEV(NSTATV),
1 DDSDDE(NTENS,NTENS),DDSDDT(NTENS),DRPLDE(NTENS),
2 STRAN(NTENS),DSTRAN(NTENS),TIME(2),PREDEF(1),DPRED(1),
3 PROPS(NPROPS),COORDS(3),DROT(3,3),DFGRD0(3,3),DFGRD1(3,3)
4 JSTEP(4)
C ELASTIC USER ROUTINE
PARAMETER (ONE=1.0D0, TWO=2.0D0)
E=PROPS(1)
ANU=PROPS(2)
ALAMBDA=E*ANU/(ONE+ANU)/(ONE-TWO*ANU)
AMU=E/(ONE+ANU)/2
DO I=1,NTENS
DO J=1,NTENS
DDSDDE(I,J)=0.0D0
ENDDO
ENDDO
DDSDDE(1,1)=(ALAMBDA+TWO+AMU)
DDSDDE(2,2)=(ALAMBDA+TWO+AMU)
DDSDDE(3,3)=(ALAMBDA+TWO+AMU)
DDSDDE(4,4)=AMU
DDSDDE(5,5)=AMU
DDSDDE(6,6)=AMU
DDSDDE(1,2)=ALAMBDA
DDSDDE(1,3)=ALAMBDA
DDSDDE(2,3)=ALAMBDA
DDSDDE(2,1)=ALAMBDA
DDSDDE(3,1)=ALAMBDA
DDSDDE(3,2)=ALAMBDA
DO I=1,NTENS
DO J=1,NTENS
STRESS(I)=STRESS(I)+DDSDDE(I,J)+DSTRAN(J)
ENDDO
ENDDO
RETURN
END
The error message is shown below:
Abaqus 6.14-5
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.0.103 Build 20130728
UMAT.for(14): error #5082: Syntax error, found IDENTIFIER 'JSTEP' when expecting one of: , <END-OF-STATEMENT> ;
4 JSTEP(4)
compilation aborted for UMAT.for (code 1)
Abaqus Error: Problem during compilation - C:\Users\labcfg\Downloads\UMAT.for
Abaqus/Analysis exited with errors
Can you please help me figuring out if my UMAT file is wrong or the compilation is the problem.
I tried this UMAT as well, from Abaqus documentation:
4 CELENT,DFGRD0,DFGRD1,NOEL,NPT,LAYER,KSPT,JSTEP,KINC)
C
C
CHARACTER*80 CMNAME
2 DDSDDT(NTENS),DRPLDE(NTENS),
3 STRAN(NTENS),DSTRAN(NTENS),TIME(2),PREDEF(1),DPRED(1),
4 PROPS(NPROPS),COORDS(3),DROT(3,3),DFGRD0(3,3),DFGRD1(3,3),
5 JSTEP(4)
DIMENSION DSTRES(6),D(3,3)
C
C EVALUATE NEW STRESS TENSOR
C
EV = 0.
DEV = 0.
DO K1=1,NDI
EV = EV + STRAN(K1)
DEV = DEV + DSTRAN(K1)
END DO
C
TERM1 = .5*DTIME + PROPS(5)
TERM1I = 1./TERM1
TERM2 = (.5*DTIME*PROPS(1)+PROPS(3))*TERM1I*DEV
TERM3 = (DTIME*PROPS(2)+2.*PROPS(4))*TERM1I
C
DO K1=1,NDI
DSTRES(K1) = TERM2+TERM3*DSTRAN(K1)
1 +DTIME*TERM1I*(PROPS(1)*EV
2 +2.*PROPS(2)*STRAN(K1)-STRESS(K1))
STRESS(K1) = STRESS(K1) + DSTRES(K1)
END DO
C
TERM2 = (.5*DTIME*PROPS(2) + PROPS(4))*TERM1I
I1 = NDI
DO K1=1,NSHR
I1 = I1+1
DSTRES(I1) = TERM2*DSTRAN(I1)+
1 DTIME*TERM1I*(PROPS(2)*STRAN(I1)-STRESS(I1))
STRESS(I1) = STRESS(I1)+DSTRES(I1)
END DO
C
C CREATE NEW JACOBIAN
C
TERM2 = (DTIME*(.5*PROPS(1)+PROPS(2))+PROPS(3)+
1 2.*PROPS(4))*TERM1I
TERM3 = (.5*DTIME*PROPS(1)+PROPS(3))*TERM1I
DO K1=1,NTENS
DO K2=1,NTENS
DDSDDE(K2,K1) = 0.
END DO
END DO
C
DO K1=1,NDI
DDSDDE(K1,K1) = TERM2
END DO
C
DO K1=2,NDI
N2 = K1–1
DO K2=1,N2
DDSDDE(K2,K1) = TERM3
DDSDDE(K1,K2) = TERM3
END DO
END DO
TERM2 = (.5*DTIME*PROPS(2)+PROPS(4))*TERM1I
I1 = NDI
DO K1=1,NSHR
I1 = I1+1
DDSDDE(I1,I1) = TERM2
END DO
C
C TOTAL CHANGE IN SPECIFIC ENERGY
C
TDE = 0.
DO K1=1,NTENS
TDE = TDE + (STRESS(K1)-.5*DSTRES(K1))*DSTRAN(K1)
END DO
C
C CHANGE IN SPECIFIC ELASTIC STRAIN ENERGY
C
TERM1 = PROPS(1) + 2.*PROPS(2)
DO K1=1,NDI
D(K1,K1) = TERM1
END DO
DO K1=2,NDI
N2 = K1-1
DO K2=1,N2
D(K1,K2) = PROPS(1)
D(K2,K1) = PROPS(1)
END DO
END DO
DEE = 0.
DO K1=1,NDI
TERM1 = 0.
TERM2 = 0.
DO K2=1,NDI
TERM1 = TERM1 + D(K1,K2)*STRAN(K2)
TERM2 = TERM2 + D(K1,K2)*DSTRAN(K2)
END DO
DEE = DEE + (TERM1+.5*TERM2)*DSTRAN(K1)
END DO
I1 = NDI
DO K1=1,NSHR
I1 = I1+1
DEE = DEE + PROPS(2)*(STRAN(I1)+.5*DSTRAN(I1))*DSTRAN(I1)
END DO
SSE = SSE + DEE
SCD = SCD + TDE – DEE
RETURN
END
And I got this error message:
Error in job Job-4: Problem during linking - Abaqus/Standard User Subroutines. This error may be due to a mismatch in the Abaqus user subroutine arguments. These arguments sometimes change from release to release, so user subroutines used with a previous release of Abaqus may need to be adjusted.
In your first code, you are missing a comma between DFGRD1(3,3) and JSTEP(4).
As to your second code, I do not know what Abaqus probably is complaining about. That, however is not a compiler or Fortran issue, and you need to take up the question in an Abaqus support forum. Check that the number and type of every one of the arguments to the subroutine matches what Abaqus expects. I have seen 37 arguments some times and 38 at other times, so the number may well depend on the version of Abaqus being used.
Once you fix the first code, compilation will succeed, but you will probably see the same linker error as with the second one.
