29293 Discussions
Linking IMSL routines any ideas gratefully received
pkmilsom
I have used IMSL routines successfully in the past after including the commands
USE numerical_libraries
USE imslf90
at the top of my Fortan programmes. Now I want to use the IMSL routine CSIEZ to carry out interpolation
Working from the IMSL example I need to include the lines
USE CSIEZ_INT
USE UMACH_INT
then I get the following error messages
Error: Error in opening the Library module file. [CSIEZ_INT]
USE CSIEZ_INT
C: est.f90(2) : Error: Error in opening the Library module file. [UMACH_INT]
USE UMACH_INT
Error executing df.exe.
when I change the USE statements to
USE imslf90
I get different error messages
C: est.f90(21) : Error: The type of the actual argument differs from the type of the dummy argument. [XDATA]
CALL CSIEZ (XDATA, FDATA, XVEC, VALUE)
C: est.f90(21) : Error: The type of the actual argument differs from the type of the dummy argument. [VALUE]
C: est.f90(21) : Error: A non-optional actual argument must be present when invoking a procedure with an explicit interface. [XVEC]
C: est.f90(21) : Error: A non-optional actual argument must be present when invoking a procedure with an explicit interface. [VALUE]
C: est.f90(21) : Error: The shape matching rules of actual arguments and dummy arguments have been violated. [XDATA]
C: est.f90(21) : Error: The shape matching rules of actual arguments and dummy arguments have been violated. [VALUE]
easy LIVE boundary.exe - 6 error(s), 0 warning(s)
The code is below
USE imslf90
INTEGER NDATA
PARAMETER (NDATA=11)
INTEGER I, NOUT
REAL F, FDATA(NDATA), FLOAT, SIN, VALUE(2*NDATA-1), X,&
XDATA(NDATA), XVEC(2*NDATA-1)
INTRINSIC FLOAT, SIN
! Define function
F(X) = SIN(15.0*X)
! Set up a grid
DO 10 I=1, NDATA
XDATA(I) = FLOAT(I-1)/FLOAT(NDATA-1)
FDATA(I) = F(XDATA(I))
10 CONTINUE
DO 20 I=1, 2*NDATA - 1
XVEC(I) = FLOAT(I-1)/FLOAT(2*NDATA-2)
20 CONTINUE
! Compute cubic spline interpolant
! Get output unit number
CALL UMACH (2, NOUT)
! Write heading
! Print the interpolant and the error
! on a finer grid
DO 30 I=1, 2*NDATA - 1
WRITE (6,*) XVEC(I), VALUE(I), F(XVEC(I)) - VALUE(I)
30 CONTINUE
END
I am grateful for any help
durisinm
You aren't calling CSIEZ with the right number of parameters. The IMSL documentation lists these as:
NDATA Number of data points. (Input)
NDATA must be at least 2.
XDATA Array of length NDATA containing the data point abscissas. (Input)
The data point abscissas must be distinct.
FDATA Array of length NDATA containing the data point ordinates. (Input)
N Length of vector XVEC. (Input)
XVEC Array of length N containing the points at which the spline is to be evaluated. (Input)
VALUE Array of length N containing the values of the spline at the points in XVEC. (Output)
Note that calling CSIEZ requires six parameters, and you're using only four. You need the NDATA and Nparameters.
Mike D.
Message Edited by durisinm on 06-08-2005 08:17 AM
You are also trying to use IMSL 5.0 modules (the _INT modules) with IMSL 4.0, as provided by CVF, which is why the modules can't be found. These are supported by Intel Visual Fortran Pro.
