Linking against acml
may_ka
初學者
1,299 檢視
Hi there,
I am running into problems linking against acml 5.3.1 with ifort 14.0.1
while "gfortran -o TestACML TestACML.f90 -L /opt/acml5.3.1/gfortran64_int64/lib/" compiles without error,
"ifort -o TestACML TestACML.f90 -L/opt/acml5.3.1/ifort64_int64/lib/" produces:
/opt/intel/composer_xe_2013_sp1.3.174/compiler/lib/intel64/for_main.o: In function `main':
/export/users/nbtester/efi2linux_nightly/branch-14_0/20140423_000000/libdev/frtl/src/libfor/for_main.c:(.text+0x31): undefined reference to `__intel_new_feature_proc_init'
/tmp/ifortWpNhTz.o: In function `MAIN__':
TestACML.f90:(.text+0x1f): undefined reference to `__intel_new_feature_proc_init'
/opt/intel/composer_xe_2013_sp1.3.174/compiler/lib/intel64/libifcore.a(for_init.o): In function `for__signal_handler':
for_init.c:(.text+0x8ce): undefined reference to `_intel_fast_memmove'
for_init.c:(.text+0x8e7): undefined reference to `_intel_fast_memmove'
for_init.c:(.text+0x900): undefined reference to `_intel_fast_memmove'
for_init.c:(.text+0x919): undefined reference to `_intel_fast_memmove'
for_init.c:(.text+0x932): undefined reference to `_intel_fast_memmove'
/opt/intel/composer_xe_2013_sp1.3.174/compiler/lib/intel64/libifcore.a(for_init.o):for_init.c:(.text+0x94e): more undefined references to `_intel_fast_memmove' follow
I found that acml ships with additional libraries libifcoremt_pic.a, libimf.a, libiomp5.a, libiomp5.so, libirc.a, libsvml.a, which have siblings in /opt/intel/composer_xe_2013_sp1.3.174/compiler/lib/intel64/
Any suggestions??
Karl
0 積分
3 回應
TimP
榮譽貢獻者 III
1,299 檢視
does it work with -L specification ahead of source file or with -static-Intel?  As the .a libraries with your compiler are likely newer than the ones which acml distributed, you might try hiding those older ones.  adding -# to the options would show detail of the link script set up by Ifort.
One of my customers found better performance even on amd platform with mkl so acml may not be kept up to date.
Steven_L_Intel1
1,299 檢視
The underlying problem is that you're linking against older copies of the Intel Fortran run-time libraries. My guess is that your ACML distribution is including these inappropriately - check for libifcore.a in the ACML directory, for example. I also agree with Tim that Intel MKL will likely give you better performance even on AMD processors.
may_ka
初學者
1,299 檢視
Hidding the libraries shipped with acml did it.
Thanks a lot.
Cheers
回覆
