29389 Discussions
Linking error for constant used in specification expression
IanH
This little program, which I think is "legal":
[fortran]MODULE Fruits
  IMPLICIT NONE
  PRIVATE            ! #A
  PUBLIC :: Get      ! #A
  CHARACTER(*), PARAMETER :: names(3) = [  &
      'Apple  ',  &
      'Orange ',  &
      'Mango  ' ];
CONTAINS
  FUNCTION Get(i) RESULT(s)
    INTEGER, INTENT(IN) :: i
    CHARACTER(LEN_TRIM(names(i))) :: s
    s = names(i)
  END FUNCTION Get
END MODULE Fruits
PROGRAM WheresThatbLinkingConstantGone
  USE Fruits
  IMPLICIT NONE
  WRITE (*, "('Eat the tasty ',A)") Get(1)
END PROGRAM WheresThatbLinkingConstantGone
[/fortran]
when compiled and linked using 11.1.065 with /warn:all /check:all /stand:f03 results in an unresolved external symbol error for _FRUITS_GET_mp_NAMES in _MAIN__.
Has that symbol been "mangled" correctly? I see _FRUITS_mp_NAMES in the symbol table which looks more like what I'd expect.
If I comment out the lines marked "#A" the link suceeds.
Thanks for any advice,
IanH
mecej4
The error message suggests that when the compiler sees the reference to "names(i)" on Line-12 it has forgotten the definition of "names" as a parameter array on Line-5, possibly as a result of a misapplication of host-association rules, specifically the attribute PRIVATE.
If "names" were undeclared, the reference to it on Line-12 would be compiled as a call to an external function "names" with argument "i", as a result of implicit typing rules coming into play.
Steven_L_Intel1
Interesting. It's not that the compiler "forgot" but it is definitely confused. I'll report it. Thanks. Issue ID is DPD200155685.
Steven_L_Intel1
Fixed in version 12.
